Scamp 5th wheel out of alignment - Fiberglass RV
Old 09-02-2019, 05:56 PM   #1
IdahoScamper's Avatar
Trailer: 1981 16' Scamp
Idaho
I have a 1992 Scamp 5th wheel that has one wheel out of alignment and wearing out tires. When I took it to an alignment shop they told me that their equipment couldn’t attach to the axle because there wasn’t enough room since the axle was too close to the bottom of the frame. Has anyone dealt with this problem? What did you do?
IdahoScamper is offline   Reply With Quote
Old 09-03-2019, 10:34 AM   #2
Trailer: Winnebago
Sounds like a bent axle. Many videos online on how to measure.
Axle will need to be straightened or replaced most likely.
Either way, it will most likely have to come off trailer.
Casita axles are delicate, do not jack on the axle, jack on the frame.
I would measure first. Straight edge on wheel to determine angle of defect. Also measure a triangle from center point on front to see if axle is crooked.
DanoFL is offline   Reply With Quote
Old 09-03-2019, 11:37 AM   #3
On our Casita we had the same problem even when it was new. We took it to an axle shop. The had to cut the axle and reweld it in correct place. Measuring it was hard since even an 1/8-1/4 inch off can cause the tire wear and you can be off by that much easily in your measuring. If your Scamp has the original axle it is probably time to replace it anyway. An alignment shop isn't the best place for a trailer unless they are specialists on trailers also.
AXLE ALIGNMENT D Tharp Towing, Hitching, Axles and Running Gear 8 09-10-2009 10:43 PM
Trailer Alignment Keith Williams General Chat 14 05-31-2009 03:34 PM
Magnetic Trailer Alignment Kit Patrick M. Modifications, Alterations and Updates 23 08-08-2008 08:15 PM
Trailer Alignment Kit Greg A General Chat 3 03-02-2008 05:45 PM
Hook-up Alignment andre robillard Problem Solving | Owners Helping Owners 1 04-26-2007 07:21 AM
