Scamp Dometic 211 Fridge Needs Help - Fiberglass RV
Old 04-05-2017, 09:44 PM   #1
I'm the proud owner of a 1981 13' Scamp. We love the thing!
Today, when i was switching the fridge (Dometic 211) from 12v to 110v the switch knob BROKE OFF! I went online and found that ,unfortunately, the switch is no longer available.
Does anyone know where i may be able to get a replacement? or is there a way to wire a series of switches to make a DIY switch to get this thing working?
Thank you all in advanced!
scampman is offline   Reply With Quote
Old 04-06-2017, 01:56 AM   #2
Borrego Dave's Avatar
You should be able to get the part # and find a replacement, it doesn't have to be factory original, just work
Old 04-06-2017, 07:56 AM   #3
That would be great. Any ideas where I should start looking for a replacement? The RV shop I called simply said they didn't stock it.
Old 04-06-2017, 11:59 AM   #4
https://www.mcmaster.com/#switch-knobs/=172yj79
Old 04-06-2017, 12:07 PM   #5
Thanks for the link Steve. My problem is that the knob is intact but the actual switch unit is broken. The know literally twisted off. I've managed to spin the unit but it no longer functions. My guess is that the internals of the rotary switch unit are damaged.
Old 04-06-2017, 12:26 PM   #6
Trailer: 1992 Casita Spirit Deluxe
Virginia
The back of an RM211 looks a whole lot like the RM2201 and RM2202. I suspect that the switch is identical as well. If you want an exact replacement, it'll probably have to come from one of these models.
There's no magic to what the switch does though - it turns on the 12V heater or the 120V heater or turns both off, allowing the gas valve to be opened. If you never use 12V mode, you can just leave all that disconnected. Then you're down to needing something like a toggle switch that interferes with the gas valve being opened when on.
steelypip is offline   Reply With Quote
Old 04-06-2017, 12:38 PM   #7
I'm sure Dometic didn't invent the switch so you will need to call Dometic and see if the part is still available. See attached parts list. Searching the replacement part number online was a fail for me so your stuck calling Dometic.
If that fails to get results then you will need to pull the cover over the switch and see if you can find the makers name and part number on the actual switch and search for that.
http://www.fiberglassrv.com/manuals/...parts-list.pdf
I did find this and it may help in your quest.
Dometic Refrigerator Selector Switch 2007664002 - $89.89
And
Dometic Refrigerator Rotary AC/DC/GA Switch - Electrical Components - Refrigerator Parts - Refrigerators - RV Appliances
Old 04-06-2017, 04:23 PM   #8
Thanks Steve and Steel.
I've called dometic and they've told me that they don't sell any replacement parts for the 211. The 2201/2 do look very similar, I'm going to look at those models as I may have better luck.
I am tempted to use toggle switches to turn on either the 110 or the 12v heating elements. Has this been done before?
Old 04-06-2017, 06:32 PM   #9
sokhapkin's Avatar
SW Florida
Sure multiple switches will work. RM 219X fridges have separate rocker switches for 12 and 110v and a warning label "do not turn on multiple heat sources at the same time" :-)
Sergey
www.callwithus.com
Old 04-06-2017, 07:52 PM   #10
How about one switch, ON/OFF/ON.
3 way, diy, dometic, fridge, mod, scamp
Trillium Dometic 211 Fridge Upgrade... Anyone? Josh Henderson Modifications, Alterations and Updates 22 10-23-2013 09:12 AM
'85 Scamp 13' Std. - Dometic 211 Fridge Tom Kaeppel Problem Solving | Owners Helping Owners 5 05-17-2008 08:50 PM
Trillium Dometic RM 211 Fridge Up-Grade Info Needed Josh Henderson Problem Solving | Owners Helping Owners 2 10-30-2006 06:10 AM
