scamp door - Fiberglass RV
Old 03-25-2008, 10:43 PM   #1
Trailer: 1980 Scamp 13 ft
Hello all,
I was wondering if the doors on a 1980 scamp and boler are the same?
Some time back I saw how Con rebuilt his door using aluminum square tubing as a new frame for the skin.
I am thinking of doing the same thing if they are constructed like a scamp door.
I've seen the scamp website photo section where you can see a door in the building stage and I think it should be easy enough to do except out of aluminum.
Building the frame shouldn't be a problem since I'm a welder but my concern is reattaching the skin to the new frame. Has anyone tried this?
Isaac is offline   Reply With Quote
Old 03-26-2008, 08:31 AM   #2
I'd think they are about as similar (shaped) as you can get without being the same. But the Scamp door has a core where the Boler door is hollow.... isn't that correct?
Old 03-26-2008, 04:34 PM   #3
Pete Dumbleton's Avatar
The Scamp has a hollow core filled with some sort of hard paper product called Buffalo Board. There was a (pre-hack?) thread about rebuilding a Scamp door that had gotten wet and heavy.
Old 03-26-2008, 04:53 PM   #4
Maybe if I make the frame out of 3/4 aluminum tubing, I could use 3/4 foam board insulation from the local lumber supply to fill in the spot.
Old 03-26-2008, 07:05 PM   #5
Alf S.'s Avatar
Hi: I have had the door apart on our '77 Boler and taken out the window for re-building. The Boler method was to glass in some strips of plywood across the door in various horizontal places. The Scamp door on the other hand was filled with Buffalo Board ( Tentest) compressed paper board. If the window ever leaks the Buffalo Board becomes like soggy bread.
A good quality tube of construction adhesive would bond the door skin to an alum. frame!!!
Old 03-27-2008, 04:28 AM   #6
DanPatWork's Avatar
Trailer: 88 Scamp 16 ft
This is exactly what we did with our Scamp door. We used the foam board with mylar as insulation in the voids, and we used 3M marine adhesive to glue the outer skin to the frame. After that we used the adhesive to glue the inner skin to the frame and then glassed the seam shut. The door ended up being about 1/2" thicker than it's original dimension but only in the opening area. Worked great and it's lighter than it was when we took it off, couldn't compare to original because we took several gallons of water out, along with soaked buffalo board.
DanPatWork is offline   Reply With Quote
Old 03-28-2008, 11:14 AM   #7
Dan Meyer's Avatar
Scamp still has pictures of how the door is made on their web site:
http://www.scamptrailers.com/images/...lery_41_06.jpg
-- Dan Meyer
Old 03-28-2008, 05:48 PM   #8
Coach George Jessup's Avatar
Send a message via MSN to Coach George Jessup
the shelf in the below post could be used to help keep the doors shape
http://www.fiberglassrv.com/board/in...howtopic=28570
Coach George Jessup is offline   Reply With Quote
Fixing scamp door Flygal Problem Solving | Owners Helping Owners 11 09-19-2018 11:53 AM
Scamp Screen Door sugermc Problem Solving | Owners Helping Owners 15 04-28-2018 06:10 PM
Scamp Door Jackie Problem Solving | Owners Helping Owners 10 02-04-2007 05:02 PM
Warped Scamp Door Legacy Posts Problem Solving | Owners Helping Owners 8 06-13-2003 11:36 AM
Scamp Door Legacy Posts Modifications, Alterations and Updates 11 05-23-2003 07:02 AM
