Scamp door latch/lock problem - Page 2 - Fiberglass RV
Old 05-19-2014, 12:51 AM   #15
Trailer: 77 Scamp 13
Hammer drill on hammer only. Very slick! Glad it worked out.
Old 05-19-2014, 07:27 AM   #16
Montana
Here are the pictures. Don't worry I will put all 6 screws back on the inside. Eventually I will also touch up the paint on the outside. The handle base has a slightly more tapered design.
corys is offline   Reply With Quote
Old 05-19-2014, 03:07 PM   #17
Just a note. If you have trouble with the door latch holding when going down the road re-position the outside door handle so it points down. As oriented bumps tend to pull the handle down a small amount. The same direction one turns the handle to open the door. Pull handle and rotate square shaft 90 degrees but only if you have that problem of the door coming unlatched.
Looks very nice.
Bargman L-66 Door lock/latch idiotsniff Classified Archives 0 09-17-2011 01:52 AM
Trillium 4500: Need replacement door lock/latch Laurie Problem Solving | Owners Helping Owners 13 06-29-2011 07:19 PM
Query about door lock to lock from inside sara maccalman Problem Solving | Owners Helping Owners 4 11-14-2010 06:11 AM
Door Latch - Lock Seized Kurt in BC Problem Solving | Owners Helping Owners 10 09-08-2008 07:16 PM
Find replacement Scamp door latch/lock Faith Problem Solving | Owners Helping Owners 2 11-02-2006 05:45 AM
