scamp electrical outlet in bed - Page 3 - Fiberglass RV
Old 10-29-2011, 11:41 AM   #29
cpaharley2008's Avatar
These things are always a good idea to have around trailer and home.
However, if a person wishes to change the plug on the end of power cord they don't help there.
Actually they will if you are replacing an outlet (1) to will tell you if you shut off the power to the outlet prior to removing the old one and (2) if you wired the new outlet properly. Unless you were referring to an extension cord, then yes they are not helpful.
Old 10-30-2011, 06:42 AM   #30
james kent's Avatar
Trailer: Boler 1984
I carry one of those testers to check the outlet at a campground. I have found quite a few where the wiring was reversed.
Old 10-31-2011, 04:23 AM   #31
Trailer: Casita 17 LD
What do you do if you find the wiring (polarity?) reversed at a campground?
Karen
Karen M is offline   Reply With Quote
Old 10-31-2011, 05:10 AM   #32
tell the management you want to be moved and if the other spot is also reversed, I'd go someplace else, poor electrical management means they are taking shortcuts in other areas.
Old 10-31-2011, 07:19 AM   #33
Thanks. I've never known to check that and I've never had a problem that I know of but then I haven't done as much camping as many of you.
Karen
electrical, scamp
Scamp electrical system Barbara Dill Problem Solving | Owners Helping Owners 4 09-02-2011 06:17 PM
Scamp Electrical Problems Lars H Problem Solving | Owners Helping Owners 13 09-08-2008 09:42 AM
AC in Scamp 13'/Electrical, Propane ?'s Tirah Care and Feeding of Molded Fiberglass Trailers 44 07-11-2008 07:54 PM
Electrical problems with Scamp 13' Russell E. Problem Solving | Owners Helping Owners 8 06-14-2008 03:49 PM
Scamp Electrical Problem gheicher Problem Solving | Owners Helping Owners 0 06-08-2006 04:03 AM
