Scamp Floor Replacement - Fiberglass RV
Old 02-23-2003, 10:02 PM   #1
Before my purchasing a used Scamp, I was concerned about the possibility of critical wood components being rotted. I contacted the Scamp company by phone to inquire about the relative liklihood that the wood might be rotten and was told that it was unlikely since the wood was 'impregnated' with resin. (They just waved the resin over the board really) It was only after buying the trailer that I discovered the 'OSB' flooring was rotted. With a great deal of work, I replaced the entire rear deck (under the dinette) with epoxy fiberglassed 3/4" plywood and also that deck under water heater! Now I have found the floor to be rotted and soft as well, so am planning on ways of replacing that.
Is there some clever way of doing this so as not to involve plywood or other moisture sensitive materials? Has anyone else on the board successfully replaced one of these crummy floors? Any suggestions?
Old 02-23-2003, 10:41 PM   #2
Hi Steve
Welcome to this forum.Great place to be.
I redid my floor in my Boler with Hardwood flooring.My floor was spongy but not rotting.It worked good for me.Some photos of Boler on the Modification&Alterations Disscusion.
:wave
Old 02-24-2003, 08:01 AM   #3
if just spongy there is a resin you can get to soak into the spongy wood and it will harden.
check this one out by Charles
http://www.fiberglassrv.com/board/read.php...780&page=1#6400
Old 02-24-2003, 09:04 AM   #4
Steve ... I'm sorry you were mislead by the factory ... like the old joke goes ...
How do you know an RV saleman is lying? When his lips are moving!
(No, I don't mean all salesmen lie! Some just occasionally gloss over the facts!)
Scamp, like Airstreams, and 99 percent of the other trailers out there are shells attached to a resin-coated floor.
There are many old Airstreams, Scamps, Bolers, etc, which, because their owners took care, will never experience floor rot of the original floor.
But, unfortunately, if something breaches the integrity of the floor (road debri, rocks, errant pieces of metal) and isn't repaired, or if someone doesn't fix an interior leak, particularly over the course of a few years, well, the wood is going to rot.
Floor rot sends more RV's to the junk yard than any other cause.
You are not the first person to encounter this. And you won't be the last.
That's the bad news.
The good news is you found this website!
There is a wealth of information, talent and advice on this website.
I'm sure we can help you overcome whatever you are facing.
Just take it a step at a time. There are many, many 30 year old fiberglass wonders still running down the road.
The really, really good news is you purchased a fiberglass trailer!
The integrity of your walls, roof, cabinets and benches is strong!
Several folks have done "frame off" restorations ... look through the old posts. Frank's A project begins is a good primer, if you want to go this route.
Rather that us repeating everything, I suggest you go back to the beginning of www.fiberglassrv.com (by clicking on the little numbers at the bottom)(there are lots and lots of pages, so you have lots to read!)
But have no fear, we'll help! Post some pictures. Ask some specific questions.
Old 02-24-2003, 09:16 AM   #5
Note to anybody looking at any old trailer:
Take a small screwdriver with you! From both the inside and the outside of the floor ... the interior and exterior ... try to push the screwdriver into the floor.
If there is a problem with the floor, the screwdriver will easily push into the wood.
Now, this is not advice that is specific to our little Fiberglass wonders. Do this if you are considering any trailer.
Some, like Airstream and Bigfoot, have belly panels, which make it difficult, if not impossible to access the exterior floor ... and it's doubtful if the seller will let you remove them anyway. So do your investigating from the interior of the trailer.
Make sure you check in front of the door, under the windows, and the back of the floor cabinets, along the walls ...
Unlike traditional stick-built trailers, our beloved fiberglass trailers will not experience any rot in the walls or ceilings, so we are way, way ahead of the game.
But it pays to check before you buy.
If you are buying sight unseen ... specifically ask the seller if there are any signs of floor rot. I'd probably even ask for it in writing! That way, when you pick it up, you'll have an "out" if you decide not to undertake the repairs.
If you do find some floor rot, and choose to purchase the rig (hey, working on these is half the fun!) ... you might be able to get the seller to lower the price.
Old 02-24-2003, 09:17 AM   #6
And Steve,
take pictures, lots and lots of picture. you want a quick reaction post a picture of the problem. most of these people can't stand to see something wrong and not tell how to take care of it. :lol :duck anyway, you might come up with something we all want to try so we need pictures. :)
Old 02-24-2003, 09:30 AM   #7
Even older Casitas ... with their solid fiberglass bottoms ... should be checked out thoroughly.
In the early 80s, Casita attached a resin-coated top-coated board to the solid fiberglass floor ... an unchecked, unfixed interior leak can cause this board to rot also!
If you find this interior floor rot, you'll probably have to remove the interior benches and install new wood ... but the floor will still be strong.
Newer Casitas have wood sandwiched in solid fiberglass ... but where ever this solid floor is breached (for plumbing, etc.), should be checked.
Old 02-24-2003, 10:00 AM   #8
Flooring
All very good points, Charles. And thanks for bringing that up about the older Casitas.
I have an '89. When I first got it, I had some elusive leaks. They realized they had a leaked somewhere and replaced the rotted area so that was not a worry to me. What was, however, was the leak they never found. The offending leak was not where they thought. On my model, the city water inlet is under the side dinette...which is next to the bathroom. They did some plumbing work (which I also redid because of a slight drip), but that was not the major source of their problem. They had acres of caulk all over the trailer, but had failed to notice the major offender. It was around the exterior vent pipe collar over the bathroom. It was pouring in, soaking the carpet then running down between the bathroom wall and the exterior wall. Where was it landing? Right under where they thought the leaks had been. There were a couple of more, but that was they key one. All has been dry since the repair was made.
Leaks may not always be in obvious places, so make sure they are all taken care of before you repair your floor.
Old 02-24-2003, 10:06 AM   #9
Another good point
Charles, this is also a very good point. Especially the shower/bathroom floor. This can be kept as dry as the rest of the trailer, if you take the time to inspect it ever so often.
As an older unit, it is not that hard to remove my shower drain, so I plan on keep a close watch on it. Make sure the plumber's putty is still good and I put marine silicone around the inside to form a seal.
Just a suggestion.
Old 02-24-2003, 10:59 AM   #10
Floor Rot
Unusual situations aside - I personally don't see how floor rot can become an issue. Obviously from leaks - but how hard can these things be to find anyway??? You'd think people would be seriously motivated to find the solution long before wood rot is an issue. One night's wet bunk would be sufficient for me...
Thinking about it - I think that one of the reasons for less problems with glass campers is that our roofs are rounded and not flat. Comparing things to roofs on homes - I've seen sloped roofs that leaked. The hole has to be pretty significant though since the water tends to run off before seeping into small holes. However - I've never seen a flat roof that DIDN'T leak. I don't care how much someone tended to it - glued rubber to it - went up every summer to patch. Flat roofs leak because the water ALWAYS pools and has lots of time to find little holes to seep into.
I had some minor leaks in the Boler around the rear window gasket. Took me about a week to find them and they're gone now.
As far as floor rot - I had plenty of chance to check when I had all the old flooring removed. I found one small (maybe 2 inch diameter) spot near the door which I smothered with fiberglass resin before putting in the new floor tiles.
mkw
Old 02-24-2003, 11:49 AM   #11
Well, I agree. Most owners would be motivated to constantly check and fix leaks or floor damage.
I think the problem occurs after the owners stop actively camping ... or circumstances change, a death or something, and the trailer just sits unused for an extended period of time.
Getting the floor wet for a day isn't going to cause the problem. It's having the floor wet over a period of years.
One of the really, really great things about our fiberglass rigs is that a leak isn't hidden in a wood-trussed roof or wall like a traditional stick built trailer.
If your rig is leaking, you are going to see it ... and be able some sort of remedial action.
Old 02-24-2003, 04:37 PM   #12
Mike, my experience, including personal, observation and anecdotal from groups like this, is that most of the rotted floors in RVs come more from *internal* leaks than external leaks (this may be because the external leaks get your bed wet and you tend to notice them quicker - grinz). Things like leaky water heaters, shower pans, toilets, drain pipes, fresh water tanks and air conditioner drains tend to be low and unnoticed (and possibly hidden), altho Suz's leaky drain vent is an exception to that.
My 13' Scamp is a 1991, and I check the underside occasionally, but have found no faults from exterior water.
I personally don't think there's much functional difference between OSB and plywood as long as they are both exterior grade, meaning waterproof glue (seems like early applications of OSB and chipboard used interior glue and gave them a bad name). Ask the owners of plywood boats who have a plywood floor sandwiched between sealed fiberglass -- if the wood manages to get wet, thru a hole or crack, it will expand and break the fiberglass, just like freezing water breaks rocks. Unfortunately, fiberglass alone isn't strong enuf economically for open spaces like floors. The best solution is to keep it all dry in the first place.
Pete and Rats
Old 02-24-2003, 09:19 PM   #13
Floor Replacement Options
Wow, what a lot of replies. Thanks for the interest. Make no mistake, I have a great deal of admiration for the essential design of this sort of trailer. If I had the time and money, I might try to build one from scratch, only using an aluminum frame and fiberglass floor, too eliminate any possibility of rot whatsoever.
The reason I despise OSB is that from what I have seen, it is far more sensitive to moisture and delamination than plywood, but that really is water under the bridge. Right now I am considering the various options for replacing the floor. By the floor, I mean the lowermost section.
In order to replace the floor with a one piece section, I would fiirst have to remove the bathroom and stove fiberglass components, then remove the secondary section of the floor OSB under them. This is a great deal of work, especially since the bathroom section would not be able to be removed from the interior, and would require quite a bit of fiberglassing. I have determined that I can insert 18 inch wide 44 inch floor sections one at a time through the doorway, then laminate them together once inside. Right now, I am trying to decide whether to use Plywood for this, or simply get some oak, possibly even salvaged pallet lumber. At the seams, maybe biscuit joints would suffice.
What I was hoping to find were clever methods of replacing the lower floor wood with the largest piece and fewest joints possible. Has anyone on this board replaced a Scamp floor?
Old 02-25-2003, 09:05 AM   #14
There are two or three here who have taken their TTs down to the axel. and started back with new floors. I know at least one took the whole box off because they showed a picture. I have always wondered how they lifted the thing. Hiring Sman <img src=http://www.fiberglassrv.com/board/uploads/3e5b8633aec36tman.gif/> seems a little far fetched. maybe they would be so kind as to tell us their method. I know one was a Boler, but they are mainly alike..?
Old 02-25-2003, 10:24 AM   #15
Lifting a Boler off of frame
I lift Boler bodies off of the frame by
using an automotive lift. Use wood blocks on the lift arms
up to the underside on the strongest ribs underneath the body.
The 4 lift points must be outside of the frame rails.
The biggest challange in getting the body off is
if you are not removing the refrig. The body is held on with
hardened sheet metal screws.
There is one of these located under
the ref. and closet and also a couple of other tight spots.
Cut these with a thin (1/32) abrasive wheel between the frame and body.
You have to jack up the body and work the
wheel into the slight gap. Once you have the body free,
the lift is raised until the frame is cleared and you can
roll the frame out. This could be done by alternating a couple of floor jacks,
but it would take longer. It takes about 3 hours to get the body off.
When reattaching the body to the frame, I use 3/8 U-bolts and seal them up.
This allows a 3' long 1" square steel tube to be added in the dinette
storage wells to strengthen the rear of the trailer.
Now you can add that bike rack and fill up the water tank
without fear of the rear frame sagging.
I have some pictures somewhere but they are in a 35mm camera. Maybe in
a couple of months I'll have them developed and scanned in.
Good luck,
Rick D.
Old 02-25-2003, 11:41 AM   #16
Just a little side note. I wouldn't recommend using biscuits to join together plank flooring, or sheet flooring, either, for that matter. While biscuits are great for cabinetry, they are still only just compressed wood fuzz. The vibration and twisting associated with rolling down the road, not to mention walking on them, can cause them to break. Now, there are some plastic or other material biscuits on the market, but I have no experience with them to comment. Paul
Old 02-25-2003, 08:12 PM   #17
Scamp floor replacment
Steve,
Oh how I know the plight your in. When I purchased my Scamp the evident floor damage was only the start. The captain of the Titanic probably thought much the same about ice. All floor sections within my unit have been replaced. You are on a good start with fiberglassed exterior or marine plywood. I would suggest glassing both sides with one layer of either 4 0r 6 oz. cloth and two applicatons of resin, it is very important to resin coat the edges completely. For any plumbing or wiring holes over drill the hole, tape the bottom of hole and fill with resin, allow to cure and then drill the correct size hole through the resin filling, run pipe or wire and then seal with a poly built silicone sealant. This method will prevent end grain water problems. I have not found an easy method of removeing the floor panels other than a complete strip of interior components and the glass shell from the frame and then remove the damaged flooring. The statment about removing the bathroom enclosure is dear to my heart. I had to approach mine as if it were a rubix cube in realationship to the door opening. Those watching were roundly entertained by my attempts and final success, now I only have to remember how to reverse the process. It is important to measure the old flooring sections from as many directions as possible before destroying or removing.. I found that when time came to bond the trailer shell to the new floor that the alignment of frame and body openings in the shell was only the first step. I then had to measure against the frame and secure the wheel wells for correct fit to the new floor pieces. I glass tabbed both upper and lower surfasces of the new floor to the shell. The bottom tabbing was first, then thickened fill between floor and shell to fill any gaps then the upper tabbing was applied.
The advice, given by others, of promptly finding any leaks is important. Water migrates along strange paths in fierglass structures. The recognition of a leak is the time to look for the source. i have raced offshore sailboats for to many years now and have often been bedeviled by a leak over my bunk. The path water often takes seems to defy gravity. With all the flexing our trailers are exposed to in transit check all seams and openings with a careful eye. Earlier threads spoke of sealant around windows appearing satisfactory yet when tested with a probe was found to have lost its' bond to the fiberglass surface and was allowing water past.
Good luck on your project, send your pictures and questions we all like to see the accomplishments others bring forth, Fx.
Old 03-04-2003, 11:01 PM   #18
Lower floor partial replacement
Because the former owner paid no attention to maintenance, much of the original OSB floor was rotten. I already replaced the rear deck and the section under the water heater (over the right rear tire), but I later discovered that the back portion of the lowermost floor was rotten as well, making the inside of the trailer smell musty in addition to being springy and weak.
I completely removed a 45-1/2" x 44-3/4" rear section, which left a floor seam right in the middle of a cross brace piece of angle steel. Structurally, this should work fine, as the steel cross piece will support the seam and prevent flexing.
<img src=http://www.fiberglassrv.com/board/uploads/3e6581e43c611BottomRear.JPG/>
I cut the old floor out and trimmed the end of the remaining floor with a straightedge and a razor knife, since the space would not allow a circular saw. The OSB, being as flimsy as it is, cuts easily with a razor knife.
<img src=http://www.fiberglassrv.com/board/uploads/3e6582c9f067cCenter.JPG/>
Next, I fit a single piece of 3/4" plywood to fit the opening. It was necessary to notch the rear corner to be able to fit it in by angling it underneath the bathroom/shower enclosure . This barely fits, but it will go in. The piece fits in the doorway and is angled in under the shower enclosure, then slid toward the rear of the trailer. It is tight, but it works.
<img src=http://www.fiberglassrv.com/board/uploads/3e658373e9bd0Replacement.JPG/>
The overhang of the shower enclosure appears as follows:
<img src=http://www.fiberglassrv.com/board/uploads/3e65848696dbcOverhang.JPG/>
Old 03-06-2003, 08:45 AM   #19
Steve, very ingenious. I think that should work great with it all treated and sealed. course I've never done it, but it's logical.
Floor Replacement Lil Bigfoot Carl G Care and Feeding of Molded Fiberglass Trailers 11 03-07-2014 04:25 PM
Bigfoot floor replacement SandraD Problem Solving | Owners Helping Owners 14 03-07-2014 04:09 PM
Glassing a replacement floor - Necessary? Carl G Problem Solving | Owners Helping Owners 9 05-19-2013 12:55 PM
Lil Bigfoot Floor Replacement Carl G Problem Solving | Owners Helping Owners 2 05-09-2010 08:43 AM
floor replacement ralph s Problem Solving | Owners Helping Owners 2 07-25-2008 11:47 PM
