Scamp furnace fan problems - Fiberglass RV
Old 11-26-2013, 04:23 PM   #1
Trailer: scamp
I have a 2010 5th wheel scamp and the other day when we found the furnace fan running when the thermostat was on off. We unplugged from external power and after a few minutes the fan stopped. Does anybody know why this happens?
jhock is offline   Reply With Quote
Old 11-26-2013, 05:17 PM   #2
It shouldn't happen and just unplugging the power cable sholdn't have fixed any known problems unless you then had a dead battery.
First suspect is the thermostat. Plug everything back in and, the next time the fan runs when it shouldn't,, disconnect one of the wires from the thermostat. If it stops after a few minutes you may have a bad thermostat. If it doesn't stopyou have a wiring troubleshooting problem of a circuit board problem to resolve. Remember, it takes a few minutes for the fan to shut down when the thermostate is turned off.
BTW: If the LP gas was OFF at the tank the fan would still run but the furnace wouldn't light off.
Good Luck
Old 11-27-2013, 08:05 PM   #3
Bet the thermostat was still trying to pull from the battery. You thought it was shut off, but when the temperature drops below whatever the thermostat is set to, it tries to fire up. There's a reason a lot of Scamp owners change the theromostat.. think you found out that reason...
Old 11-27-2013, 08:47 PM   #4
My 2006 Scamp factory thermostat has an "off" position. Once you go to the lowest setting, the lever will move with a bit of resistance another bit and turn off the thermostat. Pull the cover off, and look at the upper left corner, there should be two small pieces of metal that the plastic lever moves between.
I had to replace mine and when I did the lever wouldn't go into the off position until I did a little adjustment to the metal pieces that make up the switch.
Byron Kinnaman is online now   Reply With Quote
Old 11-28-2013, 05:50 AM   #5
Trailer: Escape Trailers
Massachusetts
new thermostat?
What thermostat do many Scamp owners change to?
Stretcher is offline   Reply With Quote
Old 11-28-2013, 07:33 AM   #6
Trailer: Casita 17 ft DLX SD
Off on a thermostat is relative At -47 deg f thermostats with a designated off position will turn on even if they are in the off position . Most home tstats have 40 deg f as their minimum set point to stop you from turning the heat off and freezing up the house by accident
Old 11-28-2013, 08:03 AM   #7
Trailer: none
When i replaced my furnace, also replaced thermostat. old one actually had a on/off switch, new one just a lever to set temp. Was surprised to go out in the trailer when it got cold and furnace fan was running, dont know if i didnt go that extra mile to actually shut it off at the thermostat or on the new one if it actually does that (have to check it out) but I just shut off power at furnace switch, guess that would the prudent thing to do anyway if not using.
Hambone is offline   Reply With Quote
furnace, scamp
For Sale: Referral - Duo Therm Furnace with Fan David Tilston Parts: Buy | Sell | Trade 0 11-18-2013 05:55 PM
Boler furnace problems. BolerBrad Problem Solving | Owners Helping Owners 1 07-24-2012 06:07 PM
Scamp Electrical Problems Lars H Problem Solving | Owners Helping Owners 13 09-08-2008 09:42 AM
Electrical problems with Scamp 13' Russell E. Problem Solving | Owners Helping Owners 8 06-14-2008 03:49 PM
Scamp Window Problems Parker Buckley Problem Solving | Owners Helping Owners 5 01-26-2008 10:29 AM
