Originally Posted by bobflhtc
My 98 Scamp doesn't have the optional Grey tank. I was thinking of using a couple of those collapsible water cubes. Just have to make sure I mark them so I don't get confused and use them for fresh. What does everyone else use ?
Thanks Bob
You can buy the tank from
Scamp and purchase the outlet piping and valve for only another $35.
If you presently have the garden hose drain on the side of the trailer and only have a sink to drain... Try this...
I installed a new 5 gal. blue (kerosene) tank just aft of the sink under the port bench. I then cut the drain line from the sink and converted the pourspout on the tank into the inlet from the sink drain. The vent on the tank was used to create a vent with a piece of tygon tubing run from the vent through a small hole in the floor. I then installed a bulkhead fitting at the bottom of the tank which i ran through an inline ballvalve under the sink the out through the side of the trailer by connecting it to the existing garden hose drain fixture on the outside of the trailer.
I then cut twenty feet from an old garden hose retaining the fitting which would attach to the trailer drain, leaving the cut end to fit into the sewer drain. The end was cut to make sure that the sewer hose was used for no other purpose.
