Hello there.....yesterday when I sent that message I to was in a little bit of a flux with hinges on my
Boler...I had taken the door to refinish off and decided to get new bolts , brass ball etc. from Ian . Any way come time to attach the door again after it being off all winter I was noticing that the door did not fit as I had thought after I put new gear together (hinges) so I fiddled with the hinges ...I had made note that the hinge had number 1 and 2 and I believe that I kept that in mind . 1 was on top and there is only really one way to put it all together once you do this...any way long story short I attached the door to trailer and with out getting to much in a flap over it fitting perfect every where was somewhat impracticable thought as its a 1973 built Boler...a lot has gone on with it I am sure over the years and well after thinking a little harder back a few years when I bought the trailer I don't think the door was perfect back then either. So I think it is what it is. The door fits almost OK and I just have to try to make adjustments where I can at this time for now...as I want to get on the road....So my friend 1 goes on top....phew long winded
