Scamp Interior Asthetics Questions-Help - Fiberglass RV
Old 07-30-2015, 05:31 PM   #1
Thee Jimbo's Avatar
OK, I am doing some work sprucing up the interior of my little 1980 scamp and there are two things I am looking for some feedback on.
1) Between the door and the front bunk fiberglass, there is a gap, maybe 1/2" in some areas. The PO used silicon Caulk in there (and it actually looked pretty good). I removed the Caulk to make it "better".
Question: is there anything I can really do (structurally or otherwise) to make it look/function better. Other than just re-caulking?
2) The wires running to the 120V lamp above the sink are unsightly, the PO put white tape over them (as you can see in the pictures), how is this light typically wired in?
3) I want to put an exterior light on the outside near the door , since all electrical is on the "opposite side" of the trailer, what is the best way to get some 12V wiring over there. i could run 1/2 " pvc under the trailer, or do I just run wires under the dinette (following the fresh water line) and do it that way. any other suggestions are appreciated as well.
I also want to run LP to that side to place a valve for a small flat heater to go under the closet door
Thanks. Jimbo
Thee Jimbo is offline   Reply With Quote
Old 07-30-2015, 07:39 PM   #2
Trailer: 2014 Escape 21
Virginia
1. Scamp installs a narrow wall there for a screen door.
2. These are 12 volt wires. Fuse, hot glue them to the shell. All this can all be covered with ALEX and painted. (I am not recommend this but I have seen it done.)
3. Get some jacketed 14-2 stranded wire Black & White conductor. Run around the back of the trailer under the benches and tie into the 12 VDC line going to the upper cabinet.
4. If you add any more 12 VDC circuits get a converter or a blue seas 6 position fuse panel.
Eddie
Questions re interior of FGRV TX Barngirl Problem Solving | Owners Helping Owners 2 05-01-2015 04:12 PM
A few questions ... okay, more like a lot of questions! shelley w Problem Solving | Owners Helping Owners 6 07-04-2012 10:25 PM
Questions about Clips around the interior / exterior windows John Truitt Care and Feeding of Molded Fiberglass Trailers 4 02-23-2009 12:14 PM
interior painting questions Naomi P Care and Feeding of Molded Fiberglass Trailers 8 02-14-2009 09:38 PM
Replacement windows, questions, questions. CliveAlive Modifications, Alterations and Updates 4 07-13-2006 07:32 AM
