Scamp lights - Page 2 - Fiberglass RV
Old 01-01-2019, 10:20 AM   #15
John in Michigan's Avatar
Trailer: 1978 Trillium 4500
Thrifty Bill, being from SE MI, when I recently replaced the 7 wire harness, I replaced all the way back to under the front bench, complete with a new sealed junction box there. With the constant freeze/thaw and road salt, I don't trust any kind of electrical box on the outside.
Trillium 4500 Journal
http://www.fiberglassrv.com/forums/f...nal-81345.html
Old 01-01-2019, 11:54 AM   #16
GMTA..
The rest of it is a solar controller, Trimetric shunt, battery shut off, etc.
Compared to having the box on the tongue, Its only slightly more work to replace the cord when the time comes. In the meantime its out of the weather
Old 01-02-2019, 03:51 PM   #17
Trailer: egg camper 13 ft
I'm more than grateful for all your help. Tomorrow we will be following instructions that I received from Dan. We are hoping to get this straightened out. I will post an update. Thanks, janis
Janis Morley is offline   Reply With Quote
Old 01-02-2019, 03:54 PM   #18
If You can... always start by hooking up to another known good Tow Vehicle.
This will either convict or be exculpatory for your TV.
As has already been said, when nothing works it is usually the ground.
We hooked another vehicle up with the Scamp. That turned out good so...it's definitely the Scamp😞. Thanks for the suggestion.
Old 01-02-2019, 05:04 PM   #19
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
Janis, if you had hooked up another vehicle to the Scamp, and then the lights worked on the Scamp, then the problem is NOT in the Scamp. The problem is in the fuses or wiring to the plug on YOUR tow vehicle.
Dave & Paula
Old 01-02-2019, 05:49 PM   #20
Hi David, I'm not responding correctly. We did that to see if there was a problem with the electrical system of our tow vehicle going to the scamp. Sadly, there's nothing wrong with our tow vehicle. It's something in the Scamp. I'm open to anything else we might try. Thanks, Janis
Old 01-02-2019, 07:33 PM   #21
.. I'm open to anything else we might try. Thanks, Janis
I thought we covered that.
Trace and test the wiring. Esp the negative. 100 ways to do it. Here is one. Use your multi-meter to check for near zero resistance from the negative (ground) terminal on the trailer plug (to the TV) and any of the negative pins on the outside lights. High or infinite resistance indicates a failed connection on the negative (ground) side. Then through process of elimination, isolate it, then repair it. Do this with no battery and no shore power. In this case you are not looking for voltage but voltage can damage the meter on continuity (ohms) setting.
Old 01-03-2019, 02:17 PM   #22
Many thanks for all your help with my lights not working on my Scamp...we got it fixed��!! It was the conversion box in the tow vehicle. I greatly appreciate all of your help!
Old 01-03-2019, 04:14 PM   #23
...Sadly, there's nothing wrong with our tow vehicle. It's something in the Scamp....
...we got it fixed��!! It was the conversion box in the tow vehicle...
Glad you got it fixed, -- we were sure confused.
Old 02-01-2019, 12:20 PM   #24
Trailer: 13' Scamp
This happened to me as well. The color codes for scamp do not match the 7pin. I would find the scamp electrical schematic,
usually the back page of the owners manual, and find the coding to the 7pin. On the scamp plug, match the wires on the plug to the 7pin. You will have to rewire the plug to match as you cannot change the 7pin. This worked for me. I have a 1998 13' Scamp.
ScamperFun is offline   Reply With Quote
light, lights, scamp
Tail lights, marker lights, reflectors jeroen Modifications, Alterations and Updates 15 10-30-2017 06:06 PM
Trillium Original tail lights/marker lights to LED Cassie Trill Modifications, Alterations and Updates 13 07-23-2016 09:04 AM
Brake Lights, Turn signal lights, marker lights, oh my! glamourpets Problem Solving | Owners Helping Owners 19 01-03-2013 10:10 AM
LED trailer lights / Non LED lights on tow vehicle Kevin K General Chat 20 11-24-2010 12:05 PM
LED lights in Original light sockets - tail lights Cam A Modifications, Alterations and Updates 75 02-15-2009 11:54 PM
