Scamp No Brake Lights/Turn Signals - Fiberglass RV
Old 07-27-2016, 11:42 AM   #1
Trailer: 13' Scamp
Kansas
Hi, brand new (to me) Scamp owner.
It's a 1981 13'. I have a 4 pin connection from my Honda Element that I've used with no problem renting a trailer at UHaul and having working turn signals and brake lights.
With my Scamp, the running lights work fine when the car lights are on, but not the brake lights or turn signals.
Ideas?
Thanks
jzaman1 is offline   Reply With Quote
Old 07-27-2016, 11:55 AM   #2
Take the trailer to an RV repair or trailer store and let them that knows what they're doing fix it.
Old 07-27-2016, 02:01 PM   #3
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
Hi Jim, welcome to the site. Congrats on getting a new to you trailer.
It could certainly be a few different things causing your light issue.
Do the tail lights and marker lights both come on fine. If not I would start with the bulbs to see that they are good. Also check the ground to the fixtures.
If the tail lights work, it is more likely something amiss with the wiring, something you would need to wring out right from the vehicle connection. Using a meter you could check continuity from the plug to the light itself, and if there is nothing you then need to trace your way back.
I am sure others might have some more insight too.
Failing that, a trip to a shop that can check it out might be in order.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 07-28-2016, 07:39 AM   #4
Trailer: 13' Scamp
Kansas
Thanks
Thanks for the advice. Electrical work has never been my strong suit. Sounds like a trip to the shop may be in order.
Old 07-28-2016, 09:18 AM   #5
Trailer: U Hall VT
Sounds like bad connection at bulb take it out and put penetrating oil on it and put it back in, see if that works for you.
Roger Kimble is offline   Reply With Quote
Old 07-29-2016, 07:27 AM   #6
Trailer: 1978 Burro
4 way trailer plug tester
Ideas?
Thanks
This thing doesn't put much of a load on the circuits but can be useful in a pinch.
Four-Way Trailer Light Tester
DuaneQ is offline   Reply With Quote
Old 07-29-2016, 11:24 AM   #7
Trailer: 13' Scamp
Kansas
Great idea
Thanks
light, lights, scamp
Help with wiring to tail lights and side signals Trillium-Pettis Electrical | Charging, Systems, Solar and Generators 21 04-06-2018 12:06 PM
Brake Lights/Turn Signals Not Working (Blowing Fuse) DeanCHS1980 Electrical | Charging, Systems, Solar and Generators 12 05-04-2016 02:13 PM
How do you make turn signals work on side lights? Rusty99 Electrical | Charging, Systems, Solar and Generators 13 05-29-2014 01:10 PM
Brake Lights, Turn signal lights, marker lights, oh my! glamourpets Problem Solving | Owners Helping Owners 19 01-03-2013 09:10 AM
Using side marker lights as turn signals al gilliland Care and Feeding of Molded Fiberglass Trailers 30 08-14-2009 04:53 PM
