Scamp plumbing - Fiberglass RV
Old 02-20-2018, 01:22 PM   #1
Scamp plumbing
I have a Casita, my camping buddy has a Scamp, we are both older ladies. Her access to dump her tanks is well under the side of her Scamp, necessating crawling under to reach the pull handles. One spot for black, one for grey. My Casita has one joined dump pipe that is located on the bottom side that I can access simply by bending over. Is there a mod that can be done so the Scamp has a single dump valves similar to my Casita? She is to the point that she doesn’t even use the black tanks, too hard to wrangle dumping!
Any suggestions about how to solve this short of selling the Scamp and getting a Casita?
Leej is offline   Reply With Quote
Old 02-20-2018, 05:01 PM   #2
Trailer: 2014 Escape 21
I use a 45 deg. Rhino fitting attached to the blackwater tank outlet. I safety wire the fitting to the outlet so it won't separate. This brings the hose connection to the edge of the shell where you can deal with it.
Eddie
https://www.amazon.com/Camco-RhinoFL...lear+connector
Old 02-20-2018, 06:37 PM   #3
Trailer: 1979 Boler 1300 / 1991 Casita Freedom Deluxe
Maine
I have also seen in a local dealers catalog a device that has a hook up to the valve and it has a wire that can actually reach inside the trailer. I will try to locate the item and give the name of it here.
Old 02-20-2018, 08:07 PM   #4
RV Doctor's Avatar
Leej. There are waste valves (which are used to dump the tanks) which are available in an electrically operated model. These install in place of the existing valves but do not require bending over or getting on your hands and knees to operate. With a switch, you merely push the switch to open or close the valve. Very easy to use! Check your local RV parts and service location where they should source and install for your Buddy.
2017 Bigfoot 25B25FB
2017 F-150 2.7 EB
Full Time RV Living
RV Doctor is offline   Reply With Quote
Old 02-20-2018, 08:21 PM   #5
Originally Posted by RV Doctor View Post
Leej. There are waste valves (which are used to dump the tanks) which are available in an electrically operated model. ..
I suspect the problem is connecting the hose... In Scamps the black water dump is up under the edge of the shell, and I too find it a PIA to hook up the sewer hose, although I dont have to crawl under the camper, only bend over a long ways or maybe get down on one knee. Once the hose is on, the gate valve is easy to open.
I even got an extension hose fixture but found that the shell was in the way so it would not fit. I do recall some discussion in this forum about combing the gray and black water dumps on a Scamp but if the problem is connecting the hose, then there are ways to modify it, using an elbow, an extension or maybe cutting out some of the shell. If that is the issue then I think that modifying the current setup to make the sewer hose easier to connect is preferable to trying to combine the gray and black water.
Old 02-20-2018, 09:34 PM   #6
John Linck's Avatar
Madison, Wisconsin
Like Eddie I find this 45 degree fitting really helps to reach under my Scamp's black tank. I swivel/rotate it down to dump and back up to travel. I think I paid about $6.00 for it. Its very well made and you can see how clear the tank is if you rinse it after dumping. I pour a gallon jug of clean water down the toilet after dumping and it runs pretty clear after that.
John
John Michael Linck - Toymaker
Subaru Outback 4 cyl cvt
John Linck is offline   Reply With Quote
Old 02-20-2018, 10:22 PM   #7
Not a solution, but being old myself, and hard or dirty ground being hard on my knees, I use those 2 X 2 foot floor pads to kneel or lay on when working near the ground, such as setting the stabilizer jacks. They are for work places, to stand on, and about the same as the interlocking play pads for kids. I've seen them at Harbor Freight, Ocean State Joblot, and similar stores. I also use them for spacing pads when packing stuff in the truck bed, between bikes and such.
Old 02-21-2018, 07:58 AM   #8
need
rv bill has the right idea but she needs a male friend to get involved maybe she can cook him a good dinner and he will do it for free!
bob
Old 02-21-2018, 08:41 AM   #9
Trailer: 2008 Casita 17 SD
Eddie
I'm curious just how this 45 degree elbow would, in any way, address the OP's problem, which is reaching the slide valves to open and close them.
If you aren't comfortable with the prospect of cutting and gluing new sections into your drain lines, (which is actually relatively easy to do,) you can probably find a neighborhood "handyman" who would probably do the job for "cost of parts" and a nice cake or a good meal, like Bob said.
You can cut the existing black and gray water drain lines and extend them outward to a point closer to the edge of the trailer, so that the valve can be situated in a position that doesn't require crawling underneath the trailer to operate the slide valves.
One of these can greatly simplify your drain line remodel by combining both tank drains at one dumping point with a little plumbing reconfiguration.
https://www.etrailer.com/RV-Sewer/Valterra/T80.html
Old 02-21-2018, 08:57 AM   #10
sort of tacky work
seems like they sort of went the cheap route doesn't it? they should know better but oh well.
bob
Old 02-21-2018, 10:33 AM   #11
Lots of suggestions but one piece of advice. BE CAREFUL if she decides to try and "combine" the two valves into one. You will have to cross over the axle at one point and will create a possible "drag" point and have the sewer pipe exposed to the road elements!! That will create a bigger problem than the valve if that happens!
I dont like having to get down and do that either. But to me, dealing with connecting/disconnecting the hose is about as aggravating to me as the valve! I can see where Scamp may could have at LEAST got them a little closer to the sides? But, keep one thing in mind. The valves are "tucked" underneath like that to help protect them from both- getting too low to the ground AND sticking out on the side and "hanging" them on something. So I guess it's a trade-off.
One suggestion I heard that sounds pretty neat- electric valves. While I wouldnt care for the extra weight, trouble-spot potential, expense, and labor to attach it, I WOULD like to see one in action.
My suggestion? Get a nice heavy-duty "kneeling" pad and maybe a small walker-like device to aid her getting up again. This would be the cheapest, easiest to deal with. If the valves get "Stuck"? Not THAT can be another issue! Good luck and let us know what you do as it's always possible someone else can use the ideas.
Old 02-21-2018, 10:43 AM   #12
yes
I agree darrall I would not want to combine because she could always have the option of the gray water going to an outside tank.
I guess at this point leave it the way it is but I think an extension of some sort on that black valve should be fairly easy to work out.
bob
Old 02-21-2018, 10:45 AM   #13
Not being a Scamp owner, I wasn't aware that Scamp holding tanks had axle interference. On my Casita, all the tanks are above the axle, and so plumbing them together is easy.
Old 02-21-2018, 10:48 AM   #14
greg
I don't have plumbing in our 13f it did at one time. I am going to pull my front cushion to see where that holding tank was it must have been there and it must have been tiny I don't see how a toilet would possibly work but since a 13f comes with a b/room apparently it does!
be interesting to know I wonder if jon would know!
bob
Plumbing Question for sink/Scamp Dave Frazer Modifications, Alterations and Updates 17 08-24-2015 01:04 AM
plumbing plumbing plumbing..... Herb P Plumbing | Systems and Fixtures 6 06-17-2007 06:01 PM
Water/Plumbing issues jefh Problem Solving | Owners Helping Owners 0 01-14-2006 12:18 PM
Bathroom Plumbing Leaks Legacy Posts Plumbing | Systems and Fixtures 4 06-20-2003 09:56 PM
Bigfoot plumbing vents Legacy Posts Plumbing | Systems and Fixtures 9 06-18-2003 09:13 AM
