Scamp table leg release - Fiberglass RV
Old 08-25-2013, 12:58 PM   #1
Trailer: Escape Trailers
Massachusetts
Question Scamp table leg release
Has anyone come up with an assist for releasing the table leg from the folded position on the standard Scamp rear-mounted table? Ours is a 5th wheel, but I think they use the same table on all models when mounted in the rear. My wife can't unfold it and doing so beats up my fingers.
Thanks,
David
Stretcher is offline   Reply With Quote
Old 08-25-2013, 01:10 PM   #2
Humm, mine isn't difficult nor does it hurt my fingers. I know it's spring loaded.... How about a short piece of PVC, with two notches cut that fit the tabs?
Old 08-25-2013, 01:13 PM   #3
Thanks,
David
A bit of lubricant will fix it. It should just pull down easily. Petroleum Jelly works pretty good and has lasted about 3 years since the last application.
No need to push or pull on anything except the table leg.
Old 08-25-2013, 01:56 PM   #4
Massachusetts
Can't just pull leg
The rectangular bar that locks the leg in place won't come over the hump in the bracket, in which the leg pivots, without manually pulling down on the bar with both thumbs while simultaneously pulling the leg out with the fingers. I just put a little oil on the spring with no change. Spring seems to compress okay, but the bar hangs up. Ours is 2011 maybe Scamp got a deal on some new brackets.
Thanks,
David
Old 08-25-2013, 06:39 PM   #5
Cyndi B.'s Avatar
Trailer: 2010 Scamp 5th Wheel/2019 Toyota Tundra
Iowa
Finger pinching.
Cyndi B. is offline   Reply With Quote
Old 08-25-2013, 07:32 PM   #6
Cricket's Avatar
Trailer: 2005 Scamp 13'
Ours is really hard to move and has given me blood blisters more than once after getting pinched.....We don't use it that often, so I keep forgetting to come up with a solution....
Cricket is offline   Reply With Quote
Old 08-25-2013, 07:47 PM   #7
Thanks,
David
Mine did the same thing until I lubricated it.
Old 08-25-2013, 10:50 PM   #8
Gilda's Avatar
Trailer: 2011 Scamp 13'
Hubbie mostly transforms the table to bed and visa versa, however I have banged my knee a number of times against the metal brackets on the wall while table is in the bed position. To cover the brackets while protecting my knees I have installed a baby crib bumper. See photo.
The Gleeful Glamper
Gilda (Jill-da)
Old 08-26-2013, 03:03 PM   #9
Thanks,
David
Put some petroleum jelly on the "hump" where the rectangular piece slides. Oiling the spring wont help.
Old 08-26-2013, 04:57 PM   #10
Massachusetts
Smile Duh!
Worked like magic. Thanks so much. My wife says she no longer needs me.
David
Old 09-05-2013, 01:28 PM   #11
Trailer: 2011 CASITA Liberty Deluxe 17'
WA
I did something entirely different. I removed the whole swing portion, mounted the prongs (the male portion) on the underside of the table and turned the holders upside down. I pluck the table out of position and slip it into the grooves to make the bed. Holds as sturdy as the old original design and eliminates the knee trouble. Pictures later if I must...
John in Seattle is offline   Reply With Quote
Old 09-05-2013, 04:39 PM   #12
Ramsey's Avatar
Trailer: 16' Scamp
Wisconsin
There was this until the petro jelly idea...stradled the post unlatching the catches .....so much for a better mousetrap.....suppose i can add a rubber band and use as a slingshot....Ramsey
Ramsey is offline   Reply With Quote
Old 09-05-2013, 04:58 PM   #13
Massachusetts
pictures
Pictures would be appreciated.
Thanks
Old 09-05-2013, 06:52 PM   #14
WA
Here are some pictures of the table modification I described earlier. Hopefully.
Old 09-05-2013, 06:55 PM   #15
That's what I thought. The title of the thread explains the OP issue. It has to do with the center support leg and it folding up to the bottom of the table when you make it into a bed.
I can see one disadvantage of your modification vs the original, once you've removed the rear of the table from the supports you have to handle the entire weight of the table. As from the factory I think it's easier to control.
Table Leg Idea Pam Garlow Modifications, Alterations and Updates 4 12-20-2012 11:43 PM
folding leg? Donny55 Problem Solving | Owners Helping Owners 12 08-17-2012 01:19 PM
Scamp Back Leg is Broken Mark J Problem Solving | Owners Helping Owners 13 11-07-2009 08:08 AM
leg pin Christi V. Problem Solving | Owners Helping Owners 12 01-13-2008 04:35 PM
