Scamp tail liters and dead battery - Fiberglass RV
Old 06-25-2015, 02:20 PM   #1
Scamp 13- My battery was losing its charge (don't know why) and then on my trip home my tail lites (brakes, signal,lights) stopped working, are they connected. Does the battery actually power tail lites. Or does it sound like I have a short in my system.
rmartin057 is offline   Reply With Quote
Old 06-25-2015, 02:26 PM   #2
Borrego Dave's Avatar
The power for all your running lights comes from the tow vehicle. You may have a loose connection, corrosion or bad ground at the plug.
Old 06-25-2015, 02:33 PM   #3
Thanks will check that out
Old 06-26-2015, 02:13 PM   #4
Name: Wayne & Barbara
Trailer: Parkliner
Iowa
If your TV is wired like mine??? The Scamp Battery and TV battery are connected together through the wire that runs from the tow battery to the trailer battery. There should be a fuse in that wire near the TV battery.
But, your scamp's tail,stop and turn signal lights are powered only from the TV's rear lamp wiring. And, it requires a ground wire circuit, not just a frame ground, as the Scamp lamps are mounted on fiberglass. A bad ground could be the cullprit./wc
battery, scamp
Dead Battery After Towing Erik in Wisco Electrical | Charging, Systems, Solar and Generators 12 11-15-2013 09:44 PM
Solar Trickle Charger & Dead Battery V'sGlassSleeper Problem Solving | Owners Helping Owners 11 03-19-2010 07:29 PM
Help dead battery & still no lights plugged in- Mark J Problem Solving | Owners Helping Owners 8 12-09-2009 05:15 AM
Miles per Gallon/ liters per 100 km for my rig! Michael Pupeza Towing, Hitching, Axles and Running Gear 2 05-21-2008 07:32 AM
Miles per Gallon/ liters per 100 km for my rig! Michael Pupeza General Chat 0 01-01-1970 12:00 AM
