Scamp tire replacement - Fiberglass RV
Old 02-28-2015, 01:33 PM   #1
Virginia
Cool Scamp tire replacement
I have a 1984 13' Scamp and need to replace the tires this year with new.
Any info on where and what to buy would be appreciated. The frame has not been replaced to make the RV body sit higher; therefore the present tires fit up under body of trailer about halfway. Thanks.
Thanks.
Sandrial is offline   Reply With Quote
Old 02-28-2015, 01:41 PM   #2
rbryan's Avatar
Thanks.
Assuming a tire size of 175/80X13, I like the Carlisle Radials. Their sport Bias Ply are fine too.
TreadDepot.com: Carlisle Radial Trail RH - Trailer Tires Black Wall (ST175/80 R13 --) 5151331
Old 02-28-2015, 02:34 PM   #3
Look at Tractor Supply and Northern Tools. They sell high speed trailer tires mounted on great looking rims.
Old 02-28-2015, 05:25 PM   #4
IllAnnoy
Carlisle RH Radial, The best I have used so far!
Old 03-01-2015, 09:58 AM   #5
Trailer: Scamp 2017 16-ft SD / FB
Attached is the milage log that for tire I have used for my 2011 SD 16-ft Scamp.
Best placed I have found to get tires is Discount Tires. Make sure that you have them balanced before installing them on the Scamp. Also good time to have wheel nearing repacked.
Henry
Scamp 2011 Maintenance / Tire Log Scamp 16-ft SD FB
SIZE Load Range Weight LoadTotal Mileage
12/11/10 Tires Tow Master (Scamp OEM) ST 195 / 13 LR C 15,172.0 miles
10/05/11 Tires Hi Run (Up Grade Tires w/ 5 Lug 14-in Rim ST 205 / 75 R 14 C 9,087.0 miles
10/08/12 Tires Master Track (Eureka MO) ST 205 / 75 R 14 C 1,760 29,284.0 miles
06/23/14 Maint - Wheel Bearing Replace /Repack 49,913.0
10/16/14 Tires Goodyear Marthon ST 205 / 75 R 14 C 1,760.0 1500 miles todate
Gattopuin64 is offline   Reply With Quote
Old 03-01-2015, 11:06 AM   #6
rbryan's Avatar
Yep, they're stock on Escapes. No issues reported.
Old 03-01-2015, 01:48 PM   #7
Trailer: scamp 16 [front bath]
SCAMP TIRES
I got mine at Costco last spring in preparation for a lot of Colorado camping and a four-week trip to the Pacific Northwest. They performed great. The one downside is that they have to be special ordered and that takes three or four weeks. The upside is the great price and the good service!
Rick in Arvada
rick in arvada is offline   Reply With Quote
Tire replacement - Balancing Tamid Towing, Hitching, Axles and Running Gear 8 10-18-2010 03:54 PM
Scamp 19' tire size? Randya General Chat 15 06-11-2009 04:54 PM
scamp 13 tire size jmacchi Problem Solving | Owners Helping Owners 2 04-12-2009 06:21 PM
Tire replacement Cam A Towing, Hitching, Axles and Running Gear 11 04-08-2008 04:13 PM
Tire replacement Cam A Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
