Scamp TV antenna - Fiberglass RV
Old 06-12-2011, 04:09 PM   #1
Trailer: 2002 Scamp 16 ft / 2014 Ford Escape
Iowa
Scamp TV antenna
My Scamp amplified TV antenna has quit working. Has anyone had experience with these, or suggestions as to what may be wrong? It is a 2002 16'. The little green light is on so there is power to the amplifier, but there is no signal getting through to the TV.
Thanks for any suggestions.
Steven F is offline   Reply With Quote
Old 06-12-2011, 04:33 PM   #2
Did you make sure all antenna connections are good and tight ?
Bill K
Old 06-12-2011, 05:07 PM   #3
Iowa
Yes, checked them all. Also tried new lead in wire from panel to TV. I am guessing there is a fault in the amplifier. May have to dig out the old multimeter.
Old 06-13-2011, 07:22 PM   #4
Trailer: 13 ft Scamp Deluxe 2007 and 40' Allegro Bus
Iowa
Send a message via AIM to RSchleder Send a message via Yahoo to RSchleder
My antenna booster did not work from the factory. I corrected the problem by replacing the electrical splices on the 12v line and all is well. The issue with the factory crimp is one pair of the wires being spliced is too small for the splice splines to cut through the insulation and make the connection.
Sounds this may not apply to your issue but it's a fairly common problem with the method that Scamp uses to make their connections to the amplifier.
RSchleder is offline   Reply With Quote
Old 06-13-2011, 07:37 PM   #5
Iowa
Thanks, I will check that out
Antenna opinions Matt in SV Care and Feeding of Molded Fiberglass Trailers 12 01-19-2012 08:59 AM
Radio Antenna Sebastian H Modifications, Alterations and Updates 13 02-26-2010 09:31 AM
Boomerang TV Antenna on Scamp Debra F. Problem Solving | Owners Helping Owners 3 07-01-2008 07:27 PM
Antenna Question Chris C Problem Solving | Owners Helping Owners 31 03-11-2008 11:05 AM
T.V. Antenna Scamp jhornsby Problem Solving | Owners Helping Owners 2 09-11-2007 11:10 PM
