scamp window leaks? - Fiberglass RV
Old 05-30-2011, 11:50 AM   #1
scamp window leaks?
just wondering if anyone has successfully caulked a side window without it looking crappy...and if so did it work?...thanks for any help you can give us..!!
marco is offline   Reply With Quote
Old 05-30-2011, 01:21 PM   #2
Kevin K's Avatar
Trailer: 1983 13 ft Scamp
Use this Heng's 3/4" Off White Butyl Rubber Tape - 20' Roll - Tapes - RV Maintenance
Silicone caulking not the best idea.
Old 05-30-2011, 01:37 PM   #3
I have done so with good success and appearance. but it involved removing the window and keeping the caulk behind the frame face.
It is generally not such a good idea to simply caulk around the frame, since the success rate is low and the appearance usually suffers.
If you were on a trip and needed to seal a window temporarily, then use an acrylic caulk from a squeeze tube, it will give some protection and won't be so hard to clean up when you are ready to make permanent repairs. The butyl tape pictured above is good and effective.
Old 05-30-2011, 02:38 PM   #4
thanks for the tips, i'll get working on it now. just bought my scamp so fiberglass is all new to me.
Old 05-31-2011, 02:54 PM   #5
Trailer: 1999 Scamp 16 ft ('The Pod')
Be sure to clean out the weep holes on the side windows. If they are plugged, water can overflow into the trailer. Carefully remove the little covers on the outside and run weed whacker line through the channel and replace the covers. Test it with spray from a hose.
Vivian is offline   Reply With Quote
Old 01-31-2012, 10:42 PM   #6
stanintn's Avatar
Trailer: 2004 13" Scamp
Thats what I would do first....may be the problem.If your trailer has been sitting awhile under trees or around alot of dust,then they are probally clogged up.It happened to me .
stanintn is offline   Reply With Quote
leaks, scamp
Leaks Brian in Ontario Care and Feeding of Molded Fiberglass Trailers 7 08-28-2012 09:07 AM
The Window to my Burro leaks Casey G Problem Solving | Owners Helping Owners 9 04-22-2011 07:07 PM
Help with leaks earnie Problem Solving | Owners Helping Owners 6 09-19-2010 02:20 PM
Fixing leaks Tom Byron Problem Solving | Owners Helping Owners 11 12-23-2009 10:27 AM
Fix for door window leaks DannyH Problem Solving | Owners Helping Owners 2 12-10-2009 08:26 PM
