Originally Posted by Lockman
I am old enough to know that you never get under any vehicle if you remove a tire without first putting the correct type of jack stands under the vehicle to prevent it falling on you. ..
But alas, wisdom does not always come with age
So glad you are responsible, I can sleep better now
But you can see how your original statement which only mentioned the inadequate bottle jack caused concern:
... My 4 ton bottle jack on the frame just before the tire work out fine and allowed me to get behind the back side of the tire to make adjustments.
BTW, The star-wheel should only go in one direction (move the shoes outward) unless the adjuster lever is pushed away from the star-wheel. The bigger challenge for me is to get the adjuster lever to release the star-wheel when I need to move the shoes in (loose). It takes two tools and some coordination. Hopefully I wont have to mess with it again however since I got self-adjusting 10 inch brakes on the
Scamp. As far as I know, there are not any self-adjusters for 7 inch brakes
