scratched, hazy 'top-hat' lights - Fiberglass RV
Old 08-24-2013, 10:23 PM   #1
Trailer: 73 Boler 13 ft
I love the original top-hat shaped rear lights on our Boler 17. But the years have not been kind. I am wondering if any of the Canadian Tire type products to polish out the scratches actually work? That would be a lot of elbow grease! Thanks.
Peggy is offline   Reply With Quote
Old 08-25-2013, 08:53 AM   #2
Trailer: Fiber Stream
I have used BlueMagic headlight lens restorer which works well enough for me. Not 100% haze free, maybe 90%... and has to be redone about once a year. I see they also make BlueMagic plastic and plexiglass cleaner. I found it at WalMart.
Old 08-25-2013, 09:33 AM   #3
Trailer: 77 Scamp 13
Originally Posted by Frederick L. Simson View Post
I have used BlueMagic headlight lens restorer which works well enough for me. Not 100% haze free, maybe 90%... and has to be redone about once a year.....
I think the reason for having to redo is that the product is part polish (gets rid of tiny, shallow scratches) and part clear "filler" that fills in and hides or minimizes the deeper or larger scratches. Have not used this exact product but the ones I have used your not going to need enough elbow grease to rub out all the scratches.
Old 08-25-2013, 09:42 AM   #4
Trailer: Casita 17 ft DLX SD
I have used Meguiar"s PLASTX on clear plastic with good results . Don't know how well it works on colored plasiic
Old 08-25-2013, 09:51 AM   #5
Trailer: none
On my daughter's Taurus, the clear headlamp lenses used 2000 grit sandpaper combined with a plastic restorer, worked well. On my 91 pickup same procedure didnt do squat on the red taillight lense's
Hambone is offline   Reply With Quote
Old 08-25-2013, 01:50 PM   #6
Brian B-P's Avatar
I haven't done a tail lamp, but I restored a headlamp kens using a kit, which turns out to be three progressively finer grits of very fine sandpaper, followed by an abrasive polish. This should work, but only on smooth surfaces. I would not expect the colour to be an issue, since it is throughout the plastic.
Old 08-25-2013, 02:45 PM   #7
Trailer: Scamp has Arrived - Layout 7
Google "toothpaste to restore plastic headlight lens"... might work on your tail light lens also. I have had success using toothpaste as a polish to remove small scratches and oxidation/chalking on a variety of materials. In order of coarseness Arm and Hammer is probably first with Vademacum in second place. Most other toothpastes fall into the least coarse category.
DJ
Dan Jones is offline   Reply With Quote
light, lights
new Scamp hat Roy Massen Parts: Buy | Sell | Trade 55 06-17-2018 08:59 AM
1980 Burro - Want to replace top red tail lights TroyBurro Modifications, Alterations and Updates 11 04-30-2013 01:45 PM
1979 17 ft Boler exterior top Marker lights Rocker Problem Solving | Owners Helping Owners 3 07-05-2012 05:24 PM
removing lights from top back of trillium Art LC Problem Solving | Owners Helping Owners 8 04-16-2012 11:59 PM
scratched stove top Peggy Problem Solving | Owners Helping Owners 4 05-17-2008 07:02 PM
