I have owned two 16 footers ... but can't remember the exact hinge arrangement, Craig.
The floor of the closet in the front a/c pops out ... just get something under it (like an right angle allen wrench) and pull it up.
If you can't reach the nuts then, I also know that you can remove the wooded trim panel around the a/c by popping off the snap caps and unscrewing them (this is the first step to removing the a/c
If you do that, can you reach a socket down to the nuts?
