SEAL-UP pop top Campster - Page 2 - Fiberglass RV
Old 03-23-2011, 03:37 PM   #15
Mike Magee's Avatar
Trailer: Li'l Hauley
I am not clear about the leak, can you clarify? Is it leaking even when the top is down, or only when it's up?
If it leaks when it's down, and you never care to have it up anyway, perhaps it could be sealed 'semi-permanently' with something like Eternabond tape. The Eternabond will not really come off (thus the name) and its sealing ability is excellent, but I think it could be cut at the joint with a blade by some future owner who wanted to raise the top again. The tough part would be how to properly tape the corners, though.
How to prepare Tofu
Step 2: grill some meat
Old 03-23-2011, 04:54 PM   #16
Greg H's Avatar
Trailer: 72 Boler American
Indiana
I permanently sealed a non working sun roof in a Jeep Cherokee once, then wished that I would have fixed it instead.
Old 04-05-2011, 08:52 PM   #17
Larry&Carrie's Avatar
Trailer: 1983 13 ft Scamp
Send a message via MSN to Larry&Carrie
Originally Posted by Donna D. View Post
We really need Larry&Carrie and/or Francene to pop in on this topic.They both have pop tops they've put a lot of work into. Don, you might consider sending them each a PM (click on the links in the names I've provided) and describe your problem. Maybe they've got a solution that will fit your needs.
DOC----- you already have my e-mail address. I told you -you should have bought mine.... That blue tarp has to go- it's not waterproof even when it is new. Larry (it's a small world isn't it?)
Larry&Carrie is offline   Reply With Quote
Old 04-05-2011, 09:04 PM   #18
Trailer: Fiber Stream
Question
Originally Posted by campfrugal View Post
Trails West Campster has a small pop-top (that) leaks too. What would you advise on sealing this thing up ?????
I just purchased this trailer today.
Can you determine if it's the FABRIC part of the top that is leaking? Or is it coming directly from the SOLID top?
My Compact Jr. leaked from the top's raise/lower arm where it bolted through the roof. There was no sealant/gasket around the bolt that penetrated the fiberglass. I took mine apart and used a bit of butyl tape to cover the hole, then poked the bolt through the tape to attach the mechanism. The butyl formed a sealed gasket around the bolt and the leaking stopped.
Old 04-06-2011, 02:52 AM   #19
alan in alberta's Avatar
Trailer: 2006 Escape 17 B Raven and a Pearl
I am new to fiberglass rv's but I have a bay window vw van with a pop top
When it was leaking I just changed the rubber gasket along the edge
Cip1.com or cip1.ca has the gaskets
alan in alberta is offline   Reply With Quote
campster
Pop Top Camper Question melissab General Chat 8 02-10-2011 10:16 AM
Adding a Pop up top to a 13' scamp Jonathan S. Modifications, Alterations and Updates 16 04-21-2008 03:56 PM
adding a pop-top? Doug Herr Problem Solving | Owners Helping Owners 3 07-16-2007 10:04 PM
Pop-top mods DonInChatt Problem Solving | Owners Helping Owners 12 02-21-2007 11:31 AM
Pop-up top? Legacy Posts Modifications, Alterations and Updates 3 04-04-2003 06:02 AM
