Sealing roof perforations-Bigfoot - Fiberglass RV
Old 07-14-2009, 10:18 AM   #1
Tony Nowak's Avatar
Trailer: 2003 Bigfoot 17 (15B17CB), 2017 Escape 17B
Wisconsin
The material on three roof perforations has failed on our 2003 trailer and now we need to address the seperation and lose of sealent. The remaining material looks to be very difficult to remove so I was planning on removing the loose ends,cleaning it up,and reapplying Pasti-cote (sp?). This material was suggested by the Bigfoot group, but they also mentioned Eternabond, though there wasn't much feedback on it.
Any feedback or recommendations are appreciated.
Tony and Darlene
Tony Nowak is offline   Reply With Quote
Old 07-14-2009, 01:30 PM   #2
Bruce H's Avatar
Trailer: Bigfoot 25 ft RQ
Hi Tony,
I have sometimes been able to reseal these by removing the excess old dried sealant around the edges and putting a new coat of “self leveling” RV sealant on it. You won’t be able to find it at Lowe’s or Home Depot. Go to an RV supply store and tell them what you need to do and they will sell you the proper sealant. It usually comes in a tube like a tube of caulking and it is cheap. If the old sealant is in really bad shape you may want to go ahead and remove the vent or fixture so you can clean all the old sealant material off then reseal it with new material. Some fixtures may need to have a strip of butyl tape put under the sealing edge before you screw it down. Butyl tape is also cheap but it is only available at RV supply stores. It in combination with the self leveling sealant will stop any leaks. I am sure the sealant Bigfoot is recommending will work.
The best way to remove the old dried sealant is to get a variable temperature heat gun to heat the material which will soften and loosen it so it can be scraped off. A heat gun is like a hair dryer but it blows REALLY hot air. A hair dryer will not get hot enough. The reason you need a variable temperature heat gun is so you can set it on a lower temperature that will not damage the fiberglass. I wound up buying one of these from this company:
http://www.howardelectronics.com/steinel/hl2010E.html
Along with the heat gun it works best to have a hard plastic scraper of some type to remove the material. You have to be careful. If you try to do it with a metal knife or scraper you will damage the fiberglass. I did find a hard plastic paint scraper at Lowe’s for about three bucks. Plastic ice scrapers are not tough enough. A polymer knife would also work. I did a quick search and found these Steck brand hard plastic tools:
http://www.autobodytoolmart.com/steck-super-scraper-71510-p-14780.aspx
http://www.autobodytoolmart.com/steck-easy-pry-tool-21730-p-11710.aspx
I don’t have these but if I do any more trailer windows or vents I will get them.
You will also probably have to have a screw driver with square drive bit for the screws on the fixture. When you are replacing screws in fiberglass do it with a hand screw driver and be gentile. A screw gun might strip it out.
Regards,
Bruce H
Old 07-15-2009, 11:48 PM   #3
Trailer: 1973 Compact Jr
A note about butyl tape -- where I live there are no RV stores. However, butyl tape is available at most of the larger glass shops.
Dana T is offline   Reply With Quote
bigfoot
Sealing Bigfoot DwayneR Problem Solving | Owners Helping Owners 3 06-13-2010 08:30 AM
Roof Sag on a Bigfoot WendyG Problem Solving | Owners Helping Owners 1 10-02-2009 07:25 PM
Roof air for a 1981 17' Bigfoot GHYNES Problem Solving | Owners Helping Owners 1 09-13-2009 04:14 PM
Bigfoot 17' Roof Access Norm Wyndham Problem Solving | Owners Helping Owners 3 07-10-2007 07:20 AM
Roof Sagging On Our Bigfoot TT ???? mitch Problem Solving | Owners Helping Owners 32 05-12-2007 09:46 PM
