Seam Tape - Fiberglass RV
Old 06-27-2007, 12:26 PM   #1
Trailer: 1975 Trillium 13 ft
Thumbs up
Does anyone know if Scamp seam tape can be used in an older Trillium, since the original Trillium seam tape is no longer available?
John L. is offline   Reply With Quote
Old 06-29-2007, 02:36 AM   #2
jaye580's Avatar
Maine
I don't know a thing about Trilliums, but I can tell you that on my 84 Scamp I tried everything to avoid replacing the seam tape as I wasn't crazy about it in the first place. After much trial and error, I finally filled the seams with almond color caulk (that matched the rest in the Scamp) and then stenciled over the seams with spray paint! It wasn't hard and I love the look. Just a thought to anyone who wants to try something other than the seam tape.
Owner of 1978 Scamp named the KRAKEN
Owner of 1987 Scamp named ANBOLINN
https://www.facebook.com/Jayes-87-L-...0486405460995/
jaye580 is offline   Reply With Quote
Old 06-29-2007, 07:09 AM   #3
Trailer: Scamp 13 ft 1982
I don't know a thing about Trilliums, but I can tell you that on my 84 Scamp I tried everything to avoid replacing the seam tape as I wasn't crazy about it in the first place. After much trial and error, I finally filled the seams with almond color caulk (that matched the best in the Scamp) and then stenciled over the seams with spray paint! It wasn't hard and I love the look. Just a thought to anyone who wants to try something other than the seam tape.
Ha,
I just finished caulking my seams, looks good. I figured a better way of caulking the seems. Place masking tape on both sides of the seams. Caulk to fill the cracks, let dry, the pull of the tape, smooth finish.
Tom C
Thomas A Cronquist is offline   Reply With Quote
Old 06-29-2007, 08:55 AM   #4
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
John, does your Trrillium still have the plastic rails in under and between the sheets of fabric?
Old 06-29-2007, 03:08 PM   #5
Thanks so much for your responses. Jaye...your trailer looks great, although John and I are not nearly as creative and ambitious as you are. : (
I do think we will go the caulk route...and yes, we do have the plastic rails.
Thanks again.
Valerie
Old 06-29-2007, 05:14 PM   #6
Doug Mager's Avatar
There is a 'thread' somewhere in here with pix of 'how to' replace missing filler(s) without the fuss n bother playing around with chalking/tape, etc. I have tried it and it works and while it doesn't look as cute as Jaye580's it IS easier and faster too!!!
Old 06-29-2007, 08:14 PM   #7
Thanks...going to look for that thread.
Old 06-29-2007, 10:42 PM   #8
Doug Mager's Avatar
Donna.....!!!
Old 06-30-2007, 06:24 AM   #9
Donna.....!!!
I don't know what to look for....seam tape, caulk????? How long ago Doug? Legacy???
Old 06-30-2007, 08:49 PM   #10
Doug Mager's Avatar
There was some discussion about replacing the plastic fill strips and someone posted a 'how to' using a length (usually sold in hardware stores in 8ft lengths) of white plastic seam conceiler (sp?) that is used usually for hiding the seams of household wallboard paneling. It is H shaped when looked at from the side and you decide which half of the H you want to use, and using a razor knife, cut off the undesired portion being SURE to leave the leg (connecting the two halves, making the H) long enough to fit into the 'track' that is on the ceiling/walls of trailers. The plastic is very easy to shape to fit and if its not fitting too too well, just warm it up and fit the leg into the track. This method leaves a smooth even surface which usually needs no touch ups (except for (maybe) paint to match surrounding areas....
This may have been posted before the krash, BTW!
Old 07-01-2007, 06:58 AM   #11
Thanks Doug, that info helped. Maybe it was the top link in this post?
help with seams
Old 07-01-2007, 08:27 PM   #12
Doug Mager's Avatar
sorry Donna, but couldn't seem to find it there, but we got close, I think, discussion about some molding... Dang, wish I was of more help!!!
Old 07-02-2007, 07:51 AM   #13
Okay, was it THIS one?
Inside Seam Tape Replacement, How to replace those ugly seams
Old 07-02-2007, 09:30 AM   #14
Doug Mager's Avatar
B I N G O !!!
Thats the one Donna!! I've been looking for it too, almost had convinced myself that I had just imagined it, LOL!
NOW, if we can only get Johns attention back here!
Seam Tape Dawn Nelson Problem Solving | Owners Helping Owners 5 10-14-2018 05:25 PM
Seam Tape Rick Harmer Problem Solving | Owners Helping Owners 6 01-23-2010 01:46 PM
Boler Seam Tape kory p Care and Feeding of Molded Fiberglass Trailers 21 06-11-2009 09:30 AM
Boler seam tape George A Problem Solving | Owners Helping Owners 2 09-06-2008 02:40 PM
Seam Tape Jason, M Care and Feeding of Molded Fiberglass Trailers 2 07-07-2008 06:14 PM
