Seam tape for Boler - Fiberglass RV
Old 04-02-2015, 08:15 AM   #1
Trailer: 1974 Boler
Manitoba
Seam tape for Boler
Hi Everyone!!
Boler newbie here!! Trying to clean ensolite to try and avoid painting.
Does anyone in Winnipeg area know where I can
purchase seam tape or order it online?
Help appreciated!!
Thanks
Excited boler newbie!!
rainey is offline   Reply With Quote
Old 04-02-2015, 09:41 AM   #2
sarahspins's Avatar
Trailer: 1984 13' Scamp named "Ramblin Rose"
Scamp sells seam tape.
sarahspins is offline   Reply With Quote
Old 04-02-2015, 10:58 AM   #3
FRED SMAILES's Avatar
Trailer: 13 ft Boler
Kootenay's of BC
I used two sided foam mounting tape and covered the exposed side with
____________ I forget, it was 12 years ago. Some of it needs replaceing but has seen TONS of service.
I used a common house hold product like starch or baking soda. I'm sure someone here knows for sure.
Seems to me I did it this way cause boler did it this way at the factory.
Happy to hear your cleaning your Ensolite!
There are a lot of different products that work well and everybody has their fav.
I have cleaned ours often and what works best for me is to use a spray bottle to apply a soap mix, a firm bristle brush to scrub it, then spray it with water sopping up the residue with dry towels and allow to air dry.
Fred
FRED SMAILES is offline   Reply With Quote
Old 04-02-2015, 03:37 PM   #4
Ian G.'s Avatar
Fred
Yes I understand the factory used talc or talcum powder on the exposed side of the 2 sided tape they used on the seams.
Old 04-02-2015, 05:48 PM   #5
Kootenay's of BC
There ya go! That makes more sence than a baking product!
Old 04-03-2015, 08:46 AM   #6
Trailer: 1974 Boler
Manitoba
If I do end up needing to paint can I paint the seam tape or just paint the caulking??
Old 04-03-2015, 08:51 AM   #7
Ian G.'s Avatar
If you don't need to paint, that is the ensulite cleans up which it should I would use seam tape. But if you decide to paint use a paintable latex caulking, the seam tape will come off eventually and need to be reapplied whereas caulking should last forever.
Old 04-03-2015, 09:41 AM   #8
Trailer: 1974 Boler
Manitoba
Thanks Ian!!!
boler
Vertical Seam Versus Horizontal Seam Cathy P. Care and Feeding of Molded Fiberglass Trailers 17 03-17-2015 11:25 AM
Getting the Seam Foam tape off of ensolite - Boler danielcaza Problem Solving | Owners Helping Owners 4 11-16-2014 11:44 AM
Compact Jr Exterior Seam Tape Sharyl Allender Care and Feeding of Molded Fiberglass Trailers 2 07-16-2009 12:00 AM
Boler Seam Tape kory p Care and Feeding of Molded Fiberglass Trailers 21 06-11-2009 09:30 AM
Boler seam tape George A Problem Solving | Owners Helping Owners 2 09-06-2008 02:40 PM
