Securing drawers while traveling - Fiberglass RV
Old 07-14-2017, 02:45 AM   #1
yankeecampergirl's Avatar
Connecticut
So excited to finally have our Sweetpea (2017 13' Scamp) in our possession! anyone figured out a good way to keep the drawers closed while traveling?
Thanks!
Karen
Karen M[FONT="Comic Sans MS"][/FONT
yankeecampergirl is offline   Reply With Quote
Old 07-14-2017, 03:12 AM   #2
TomK's Avatar
Karen, the only drawer we had on our Standard 13 was the silverware drawer. If it was pushed all the way in; it never opened on the road. If you meant the cabinet doors, that was a bit of a problem until I "pinched" the metal clips on the doors so they would hold tighter to the rollers on the cabinet. I used pliers and gently closed the clips a little at a time, until they were a little stiff to close. Same fix for the curtain rods if you find them falling off when under way.
The refrigerator door has a locking latch to keep it closed on the road as well. If you study it, you'll see it has two positions. If you close the frig door and swing the latch to hold it, it should stay shut. For storage, you can open the door a little and swing the latch in order to hold the door open to air it out and prevent mold. If the latch itself (ours was black) loosens, simply tighten it with a phillips screwdriver.
We always load the biggest, heaviest things on the floor and close to the axle to prevent surprises when we check the trailer at gas or rest stops. Good luck with your new trailer. You will love it!
TomK
Old 07-14-2017, 03:16 AM   #3
Connecticut
Thanks, Tom! That sounds way simpler than what I was thinking! I cant wait to see it in person, Anthony getting home today (!) from Backus!
Old 07-14-2017, 09:32 AM   #4
It's a little messy, but I use white duct tape to keep things shut when I'm traveling.
Postman is offline   Reply With Quote
Old 07-14-2017, 09:53 AM   #5
There's this thing called kinetic energy. When released can cause things to happen. Heavy objects have more of this energy than light objects. When you start an object moving it go until something stops it.
Now how does this apply to drawers and cabinet doors. Simple, when stuff in cabinets or drawers moves and hits the front of the drawer or a cabinet door there is often enough energy to open said items.
Options to prevent such an occurrence. Keep only light items in storage places with doors or drawers. Keep the items from moving by various means. Fix the doors and drawers so it takes more energy to open i.e. tape or hardware.
Here's what I've done. Overhead cupboards have the stuff in plastic boxes of appropriate sizes that or tight fitting so they don't move. And only light stuff in the drawer. Very little problem in 11 years and close to
100,000 miles.
Old 07-14-2017, 11:26 AM   #6
Trailer: Compact Junior
Saskatchewan
Smile Drawers and their security
We use a system of small screw-in eyelets and fasteners.
Closets? One screw eye on door and one on the frame with a small 'hairpin' fastener engaging both
Stack of drawers? One screw eye in top frame and one screw eye in bottom frame with a thin tube or rod down through the two (we use a tiny threaded rod with a nut on upper end)
jish is offline   Reply With Quote
Old 07-14-2017, 11:39 AM   #7
Mike Magee's Avatar
Trailer: Li'l Hauley
I have used a strip of velcro on a fridge door that kept opening. It was a dorm type AC fridge, no door lock. I had the velcro about 2" on the front and 3" on the side, so the strip wrapped around.
On drawers that just won't stay closed, a plastic child-proof catch can help. Hardware stores have them.
In the '60s, people took LSD to make the world seem weird.
Now the world is weird, and people take Prozac to make it seem normal.
Old 07-14-2017, 11:51 AM   #8
I use bungee cords through the handles. That way I have no permanent eyesores. Of course, you need the right handles.
Light items go in top cupboards and heavy items in lower cupboards.
Old 07-14-2017, 12:14 PM   #9
Trailer: Scamp 13'
Kentucky
mini bungee cords
Walmart sells containers of 10 little black bungee cords about the diameter of a shoe string and 6" long. Attach one end of the cord to the locking side of the fridge and stretch it to the hinge side bracket. It matches the trim color of the fridge so isn't noticed. When you travel lift the cord up and over the knob of the silverware drawer. We have traveled many miles in our 13' scamp and have never had a problem with fridge or drawer. Occasionally the overstuffed closet door wants to open. We use another small bungee cord looped around the closet knob and stretch it to the knob on the screen door and that keeps everything closed. You're getting the new type of screen door so it may not have a knob. You have purchased a great little trailer, hope you enjoy it for many years.
Danny1953 is offline   Reply With Quote
Old 07-14-2017, 12:41 PM   #10
likeair2me's Avatar
Trailer: 1981 SCAMP 13
I just hold on real tight.
likeair2me is offline   Reply With Quote
Old 07-14-2017, 01:29 PM   #11
Connecticut
Thats perfect!!! Thank you!!!!
Old 07-14-2017, 01:32 PM   #12
This has probably been the biggest challenge in our Campster. I use Glenn's bungee solution and have smaller bolts by the dorm fridge but but things are still opening part way. I've seen some ideas to try and will continue to watch for more.
Dave Fish is offline   Reply With Quote
Old 07-14-2017, 02:09 PM   #13
charlsara's Avatar
Trailer: 2014 Lil Snoozy
We had that problem. Philip-it latches took care of it.
Old 07-14-2017, 03:55 PM   #14
We have a couple of those, but I think they are no longer available
Internet Connection while traveling - New from Virgin Brian Van Snell Problem Solving | Owners Helping Owners 24 12-30-2010 08:49 AM
Keeping Door shut while traveling? Trillium 4500 Fred G. Problem Solving | Owners Helping Owners 14 03-18-2007 08:58 AM
Security while Traveling alone Gina D. General Chat 61 06-21-2006 05:01 PM
Speaking "American" while traveling Gina D. General Chat 69 01-24-2006 08:31 PM
D'ya wash tow vehicle while traveling? Legacy Posts Care and Feeding of Molded Fiberglass Trailers 8 09-26-2002 08:14 PM
