Seeking replacement recommendations for "Cable Hatch" on 1975 Trillium 1300 - Fiberglass RV
Old 05-24-2018, 05:04 PM   #1
The flap for my "cable hatch" finally flipped it's lid and no longer is attached..
Being the kind of guy that wants to keep his Trillium as "stock" as possible I am wondering if anyone out there might have a spare "cable hatch" assembly in a corner somewhere??
If not, I am sure that others here have replaced an old "cable hatch" with a new one and am wondering if they could share with me the specs/name of a replacement that does not require a whole bunch of fiber-glassing..
Any suggestions would be appreciated..
Chris from Comox..
Chris from Comox is offline   Reply With Quote
Old 05-24-2018, 05:20 PM   #2
mszabo's Avatar
Trailer: U-Haul VT16
What is a cable hatch? Do you have a picture of your hatch? so we can help you find one.
Old 05-24-2018, 06:07 PM   #3
Good question.. The "Cable Hatch" is the plastic "flap" that one lifts up to pull out the 120v AC power cord.. The "flap" on mine has broken off and I am seeking a replacement for the entire unit..
Chris from Comox..
Old 05-24-2018, 06:30 PM   #4
David Tilston's Avatar
Not being a fan of pushing rope, (cable?) I did this:
http://www.fiberglassrv.com/forums/f...ded-50948.html
Old 05-24-2018, 06:32 PM   #5
John in Michigan's Avatar
Trailer: 1979 Boler 1700
what a coincidence!
I was in the same predicament 2 years ago, and tracked one down, then installed it on my Trillium 4500. Let me see if I can figure out where the heck I found it.
Old 05-24-2018, 06:39 PM   #6
bingo
ok here's where i bought it!
https://www.amazon.com/Zebra-RV-EC14...7208693&sr=8-4
Old 05-24-2018, 06:42 PM   #7
or in Canada:
https://www.amazon.ca/Zebra-RV-EC147.../dp/B004RCV0JM
Old 05-24-2018, 06:49 PM   #8
I actually cut the cable down to about 2 feet, and then I plug a high amp extension cord into it, keeping that connection inside the camper. I even have a thru-hull 110 vac connector, just haven't bothered to go that route yet...
Currently repairing the 4500 belly band and re-sealing the rear window at the same time. Then we'll probably get back to our first priority, camping!!!
Old 05-25-2018, 09:13 AM   #9
brendadave's Avatar
Trailer: 1976 Trillium 13 ft
I bought one at my local RV parts store, was the same dimensions as the original.
Old 05-25-2018, 09:22 AM   #10
Trailer: '78 Trillium 4500
Only in Canada, you say?
Pity.
Actually, I bought something like this, only rectangular, at a local RV service/supply shop here in Edmonton. It wasn't very expensive, and just required some sealant and a few stainless screws to install.
https://www.campingworld.com/electri...le-hatch-white
I just installed a couple of large hatches on the rear of my Trillium 4500 to provide better access under the dinette benches (we leave the bed set up 24/7). Most of the windows were re-seated a couple years ago, but I am still getting some moisture in from somewhere...
Capn.Curt.Wiebe is offline   Reply With Quote
Old 05-25-2018, 11:32 AM   #11
Larry C Hanson's Avatar
Hi,
Here is the one I used...
https://www.ebay.com/itm/RV-trailer-...oAAOxyaTxRSK7b
Can't remember what the original one looked like?
Larry H
Old 05-25-2018, 11:46 AM   #12
Thanks everyone..
Amazon and Ebay were out of stock but I was able to find one in California and at a great price.. Even with the exchange ;-)
https://www.rvautoparts.com/EC-147-C...ch_p_1965.html
Chris from Comox..
Old 05-25-2018, 11:52 AM   #13
Trailer: 1980Trillium 1300
Here is mine. Share...
http://www.fiberglassrv.com/forums/f...ler-60620.html
Old 05-25-2018, 12:25 PM   #14
thumbs up
Chris from Comox, that's great! The item you ordered (same one I ordered) is an exact match, with same fastener holes and same sized center hole. At the time I bought and installed it, I did it because I wanted to get the camper functional to take it camping. I wasn't ready to decide at that point whether I was going to:
- stick with the 120vac 15 amp system
- upgrade to a 120vac 30 amp system
- etc, etc
Two years later I still haven't changed it out, however, I repaired the original power center:
- replaced the faulty old transformer with an electronic power supply
- replaced the two circuit breakers and the spdt switch
John
Old 05-25-2018, 06:04 PM   #15
Chris McVeigh's Avatar
Trailer: 1978 Trillium 4500
http://www.fiberglassrv.com/forums/f...nts-38176.html
Did this job a while back on my 78 Trillium
Chris McVeigh is offline   Reply With Quote
Old 06-17-2018, 12:15 PM   #16
Trailer: One 13 ft Scamp and One 13 ft Trillium and Two Trillium 4500
If you are planning on replacing the Cable Hatch I recommend you try my trick..
I installed one of these connectors "inside" one of the Cable Hatches like the one pictured and sealed it.. This done 2 things..
(1) I never again had to climb under my bed to fish out the electric cable since it always fell into the storage bend once done...
(2) It put a stop to ants, bugs and MICE climbing up the electric cable into my camper.. That was always a problem...Just carry a drop cord and your always ready...
Randy Bishop is offline   Reply With Quote
Old 06-18-2018, 06:52 PM   #17
Thanks everyone.. Problem solved, I found an exact replica of the original Cable Hatch and within 5 min had the old one out, the new one butyl taped on the backside and the 4 pop rivets in-place.. Good as new ;-)
Chris from Comox..
eco, trillium
Problem with power cable hatch hole size Tyhee Problem Solving | Owners Helping Owners 10 03-27-2016 12:06 PM
Seeking recommendations HustonFamily Camping, Campout Reports 2 02-16-2009 10:09 PM
