Seeking replacement recommendations for "Cable Hatch" on 1975 Trillium 1300 - Fiberglass RV
Old 05-24-2018, 06:04 PM   #1
The flap for my "cable hatch" finally flipped it's lid and no longer is attached..
Being the kind of guy that wants to keep his Trillium as "stock" as possible I am wondering if anyone out there might have a spare "cable hatch" assembly in a corner somewhere??
If not, I am sure that others here have replaced an old "cable hatch" with a new one and am wondering if they could share with me the specs/name of a replacement that does not require a whole bunch of fiber-glassing..
Any suggestions would be appreciated..
Chris from Comox..
Chris from Comox is offline   Reply With Quote
Old 05-24-2018, 06:20 PM   #2
mszabo's Avatar
Trailer: 1986 Bigfoot FT20
What is a cable hatch? Do you have a picture of your hatch? so we can help you find one.
Old 05-24-2018, 07:07 PM   #3
Good question.. The "Cable Hatch" is the plastic "flap" that one lifts up to pull out the 120v AC power cord.. The "flap" on mine has broken off and I am seeking a replacement for the entire unit..
Chris from Comox..
Old 05-24-2018, 07:30 PM   #4
David Tilston's Avatar
Not being a fan of pushing rope, (cable?) I did this:
Power inlet dimensions needed
Old 05-24-2018, 07:32 PM   #5
John in Michigan's Avatar
Trailer: 1978 Trillium 4500
what a coincidence!
I was in the same predicament 2 years ago, and tracked one down, then installed it on my Trillium 4500. Let me see if I can figure out where the heck I found it.
Trillium 4500 Journal
http://www.fiberglassrv.com/forums/f...nal-81345.html
Old 05-24-2018, 07:39 PM   #6
bingo
ok here's where i bought it!
https://www.amazon.com/Zebra-RV-EC14...7208693&sr=8-4
Old 05-24-2018, 07:42 PM   #7
or in Canada:
https://www.amazon.ca/Zebra-RV-EC147.../dp/B004RCV0JM
Old 05-24-2018, 07:49 PM   #8
I actually cut the cable down to about 2 feet, and then I plug a high amp extension cord into it, keeping that connection inside the camper. I even have a thru-hull 110 vac connector, just haven't bothered to go that route yet...
Currently repairing the 4500 belly band and re-sealing the rear window at the same time. Then we'll probably get back to our first priority, camping!!!
Old 05-25-2018, 10:13 AM   #9
brendadave's Avatar
Trailer: 1976 Trillium 13 ft
I bought one at my local RV parts store, was the same dimensions as the original.
Old 05-25-2018, 10:22 AM   #10
Trailer: '78 Trillium 4500
Only in Canada, you say?
Pity.
Actually, I bought something like this, only rectangular, at a local RV service/supply shop here in Edmonton. It wasn't very expensive, and just required some sealant and a few stainless screws to install.
https://www.campingworld.com/electri...le-hatch-white
I just installed a couple of large hatches on the rear of my Trillium 4500 to provide better access under the dinette benches (we leave the bed set up 24/7). Most of the windows were re-seated a couple years ago, but I am still getting some moisture in from somewhere...
Capn.Curt.Wiebe is offline   Reply With Quote
Old 05-25-2018, 12:32 PM   #11
Larry C Hanson's Avatar
Hi,
Here is the one I used...
https://www.ebay.com/itm/RV-trailer-...oAAOxyaTxRSK7b
Can't remember what the original one looked like?
Larry H
Old 05-25-2018, 12:46 PM   #12
Thanks everyone..
Amazon and Ebay were out of stock but I was able to find one in California and at a great price.. Even with the exchange ;-)
https://www.rvautoparts.com/EC-147-C...ch_p_1965.html
Chris from Comox..
Old 05-25-2018, 12:52 PM   #13
Trailer: 1980Trillium 1300
Here is mine. Share...
Power Cover for Classic Trillium Trailer
Old 05-25-2018, 01:25 PM   #14
thumbs up
Chris from Comox, that's great! The item you ordered (same one I ordered) is an exact match, with same fastener holes and same sized center hole. At the time I bought and installed it, I did it because I wanted to get the camper functional to take it camping. I wasn't ready to decide at that point whether I was going to:
- stick with the 120vac 15 amp system
- upgrade to a 120vac 30 amp system
- etc, etc
Two years later I still haven't changed it out, however, I repaired the original power center:
- replaced the faulty old transformer with an electronic power supply
- replaced the two circuit breakers and the spdt switch
John
eco, trillium
Problem with power cable hatch hole size Tyhee Problem Solving | Owners Helping Owners 10 03-27-2016 01:06 PM
Square Cable Hatch Deb & Chuck Commercial Posts and Products 2 10-28-2012 06:47 PM
Wanted: Lil Bigfoot power Cable Hatch MsRubyLu-Kathy Parts: Buy | Sell | Trade 15 09-30-2012 08:16 AM
Wanted: 1978 Trillium 1300 Parts - Replacement Hatch w/fan, hub caps, Door Hardware.... Perseustheegg Parts: Buy | Sell | Trade 1 08-17-2012 06:04 PM
Seeking recommendations HustonFamily Camping, Campout Reports 2 02-16-2009 10:09 PM
