Separating shell from frame - Fiberglass RV
Old 05-22-2008, 08:20 AM   #1
Roddy D's Avatar
Trailer: Scamp 16 ft
I am in the process of purchasing a 1984 13' scamp. The trailer is in bad shape and looks like a total rebuild. I was wondering if anyone could give me advice on how to separate the shell from the frame. I've searched the forums and not found any anything on this process. Is there an easy way to jack up the shell from the frame or is brute strength required.
Any help would be greatly appreciated...
Roddy D is offline   Reply With Quote
Old 05-22-2008, 08:35 AM   #2
The shell is mounted to the frame using carriage bolts and fender washers. The best way to find most of them is from underneath.
Hopefully someone who's recently separated the two will pop in with further info.
Please keep us in the loop of your rebuild, sounds like quite a project. We'd love to see some pictures of the process too!
Old 05-22-2008, 11:41 PM   #3
Roy in TO's Avatar
I know there are pictures here, seen some with the body on 5 gallon buckets. Someone else fabricated plywood jigs that fit under the belly band.
Basically you jack up the entire trailer, cut the bolts/screws etc. support the body then lower the frame.
Old 05-25-2008, 03:06 PM   #4
Roddy D's Avatar
Thanks for the insight. I went out to my 16' Scamp trailer and took a look. Now this makes perfect sense.
Have not heard from the seller of the 13' Scamp trailer as of today. I will be well prepared to attack the trailer when/if the purchase goes thru.
I found my old digital camera last night and will post pictures when able
Thanks for the help.
Need Help Painting Shell!! harold f Problem Solving | Owners Helping Owners 18 07-22-2010 07:46 PM
Empty Shell Stoney General Chat 9 10-07-2009 05:37 AM
Empty Shell Help Heather V. Care and Feeding of Molded Fiberglass Trailers 8 09-07-2007 05:57 AM
What would you put in a 13 ft. shell? Kent I Care and Feeding of Molded Fiberglass Trailers 8 09-02-2007 01:38 AM
Soft Shell Jason L. Problem Solving | Owners Helping Owners 18 01-20-2006 10:09 AM
