serial number - Fiberglass RV
Old 10-11-2006, 05:20 PM   #1
Yvon Chayer's Avatar
Trailer: Bigfoot 17 ft 1992
Quebec
I own a boler 78 , when i repaint it , i remove the tag with the serial number stick on left side of the shell
Boler have a other serial number ??? stamp on frame ??
If it have , where is it ???
Thank you
Yvon Chayer
Yvon Chayer is offline   Reply With Quote
Old 10-11-2006, 05:50 PM   #2
Brian B-P's Avatar
The serial number likely also appears on a sheet of paper stuck inside a cabinet (the closet in mine), which lists the manufacturer's name, date manufactured, appliances installed, weight ratings, etc. The plate on my trailer's frame is just a statement to look inside for the serial number... no real information there.
This is mine for an example:
VIN number Mariusz Wolanin Problem Solving | Owners Helping Owners 7 04-27-2018 12:42 PM
Where is the vin number? Ricky 4 Problem Solving | Owners Helping Owners 2 02-04-2010 10:16 PM
Found Serial number Tim R General Chat 3 05-20-2009 07:10 PM
Serial Number David Thomson Care and Feeding of Molded Fiberglass Trailers 4 01-22-2007 09:13 AM
Serial Number General Chat 0 01-01-1970 12:00 AM
