Setting tension on sway control - Fiberglass RV
Old 04-13-2006, 02:01 PM   #1
Chris Z's Avatar
Trailer: 2005 Casita Spirit Deluxe 17 ft (was 2003 16 ft Scamp)
OK
I think I have my sway bar all mounted now. By rotating the handle, I get varying degrees of tension between the two sliding parts. I'm going to guess I set it so that if I pull real hard that it will slide and see what happens on the road. Is that where I start?
If I have too much tension between the two, how do I know?
Chris Z is offline   Reply With Quote
Old 04-13-2006, 04:47 PM   #2
Al V's Avatar
Send a message via Yahoo to Al V
I dont know for sure, but the one i recieved withe the casita say 3 turns of the handle to release tension. the adjusting nut is pre set for 1300 pounds.
if this does not give enought sway protection tighten nut 1/4 turn and try again.
and to take out the bar and clean with steel wool after fisrt 1000 miles then every 10000 miles .
never lubricate or paint the slide bar.
notes say not to use bar on wet , icy or oily roads ( guess that leaves 75% of the country out)
i tuun the handle till it is hard to turn and the hadle is not in a position to spear any body parts
hope this help
Al V is offline   Reply With Quote
Old 04-13-2006, 05:13 PM   #3
Suz
Suz's Avatar
Trailer: 1989 Casita Spirit Deluxe
I was always told (and my instructions stated the same thing) to hand tighten then back off a half a turn. That's still somewhat ambiguous, but that's what I've done and it's worked perfectly for me.
I wouldn't mess with the hex nut. Our trailers aren't that heavy. Perhaps when it's old and worn, you might have to, but I wouldn't think it'd be necessary when it's new. Just my opinion, of course.
Suz is offline   Reply With Quote
Old 04-13-2006, 10:29 PM   #4
[quote]
Just curious....Is this after you put your trailer back onto it`s wheels and get it out of the ditch?...Benny
Equal-i-zer®'s 4-Point Sway Control™ Bigfoot Mike Towing, Hitching, Axles and Running Gear 2 06-19-2008 06:37 AM
Reese Double Cam Sway Control bobinyelm Towing, Hitching, Axles and Running Gear 30 07-23-2007 09:34 PM
About to do a DIY Sway Control install Gina D. Towing, Hitching, Axles and Running Gear 27 07-15-2007 08:48 AM
Sway control Legacy Posts Problem Solving | Owners Helping Owners 4 05-04-2003 07:34 AM
Sway control General Chat 0 01-01-1970 12:00 AM
