Sewer tank flush is blocked - Fiberglass RV
Old 10-18-2019, 01:14 PM   #1
Trailer: Shopping
Montana
I have a 2014 Rpod 178. No water flows when I hook up a hose to my sewer tank flush. I can't trace the line since it goes inside the floor and across the trailer to the curb side. Any thoughts on where blockages likely occur? I can see where the flush line enters the tank, so I can pull the hose out of the tank and check the spray nozzle for a blockage. Seems odd though, since I have never used the black tank for anything solid, only urine. Other possibilities? Is there a back flow prevention valve on the line somewhere that may be blocked, and how would you access it? Thanks for any insights you can provide.
Gary Luna is offline   Reply With Quote
Old 10-18-2019, 06:11 PM   #2
Jon Vermilye's Avatar
Trailer: 2017 Escape 21
Oswego, NY
Every built in tank flusher I've seen has a back flow preventer. often part of the hose connection.
Old 10-19-2019, 09:19 AM   #3
Massachusetts
One would think that the back flow preventer would be located right at the external hose connection, that way it could be replaced easily if it failed as possibly in your case.
Maybe best to contact the mfg for that information.
Lockman is offline   Reply With Quote
Old 10-20-2019, 10:20 AM   #4
dleverton's Avatar
Trailer: Trillium 1300 1973
There is an instructional video on just this sort of issue called “RV” with Robin Williams.
Doug
dleverton is offline   Reply With Quote
Camco Dual Flush vrs. Valterra Flush King on a Scamp 13 Lockman Problem Solving | Owners Helping Owners 1 08-07-2018 09:53 AM
sewer tank wax gasket? hiker22 Plumbing | Systems and Fixtures 6 04-24-2018 10:38 AM
PM's blocked Joy A Forum Admin, News & Announcements 8 01-08-2008 09:26 AM
Full-Time RVers Are Blocked From Voting Donna D. Fulltiming in a Molded Fiberglass Trailer 21 11-25-2007 05:53 PM
Tornado Black Water Tank Flush Kit mitch Care and Feeding of Molded Fiberglass Trailers 16 07-14-2007 09:07 AM
