Shademaker Delux Awning mounting problems - Fiberglass RV
Old 08-01-2009, 10:40 PM   #1
I just installed a Shademaker Deluxe Awning (slid it into the rail) and discovered that when i set it up, it is a pretty tight fit. The arms extending from the trailer do not have enough room to add the little black receivers that the balls are to fit into. This is mostly due to the curvature of the roof line as I have my rail quite high. Anybody else have this problem? Suggestions?
Lisa A is offline   Reply With Quote
Old 08-01-2009, 11:13 PM   #2
Greg A's Avatar
Trailer: 2015 Escape 19
Hi Lisa,
You don't mention what size awning or what type of trailer, but here is my install thread of a Shademaker 8' Premium Awning on a Scamp 13 and how I located everthing.
Has worked without a flaw since installation about 7 months now.
Shademaker Awning Install
Owner:
Fiberglass-RV-4Sale.com
Scamp Owners International
Old 08-02-2009, 06:29 AM   #3
Alistair Camelford's Avatar
Trailer: Trillium 13 ft 1973
Hi Lisa...I experienced the same situation with my 9"awning. I installed the awning rafter receivers under the awning bag (see Greg's excellent photos ) but the arms were too long when fully extended. I solved this by drilling new holes for the detents ( the little ball on spring thingies) a little further up the arm. The detents slide out and can be re-inserted easily. One caveat...make sure you drill the hole for the new spot in exactly a right angle so that both detents engage .
To measure for the new spot...set up awning, engage rafter fully, mark the edge of the inner rafter where it exits the larger channel,then re-mark it where the detents engage. Remove the inner channel. The difference between where the factory detent holes are, and where your new holes will have to be, is the distance between the two marks.
Good luck. Remember the carpenter's adage " Measure twice- cut once"
Alistair
Alistair Camelford is offline   Reply With Quote
Old 08-16-2009, 09:58 PM   #4
Hi Lisa,
Thanks for the advice. The photos are a great help. It is now on the "to do" list. Cheers.
Shademaker 8 foot Awning Install 13 Scamp Greg A Modifications, Alterations and Updates 29 04-23-2016 04:15 PM
Trimline vs Shademaker awnings April Wilcox Problem Solving | Owners Helping Owners 34 08-22-2013 06:54 PM
Re-Mounting my awning Ed Harris Problem Solving | Owners Helping Owners 3 07-23-2007 01:03 PM
Mounting an Awning on a Burro (double shell) S Sato Modifications, Alterations and Updates 17 03-05-2006 07:16 PM
Scamp 5th Wheel Delux Legacy Posts Modifications, Alterations and Updates 4 12-03-2002 07:51 AM
