Sheets! - Fiberglass RV
Old 07-28-2013, 05:26 PM   #1
courtney's Avatar
Trailer: 1982 13ft Scamp purchased on May 2nd
Sheets!
I've seen some folks asking questions about sheets for the rear bed of the Scamp. I bought a a set of twin jersey sheets from Target and the fitted sheet fit the rear bed perfectly! I cut the top sheet in half and will make fitted sheets for the bunks as soon as I find the time.
courtney is offline   Reply With Quote
Old 07-28-2013, 05:30 PM   #2
Jersey sheets are GREAT for these all molded towabes. Stretchy!
Old 07-30-2013, 07:55 PM   #3
james kent's Avatar
Trailer: Boler 1984
My wife bought three sheets on sale at a Walmart. She used one for a top sheet and then cut one up to add a foot to either side of one for a bottom sheet that would tuck in. The remainder she used to make matching pillow cases and curtains. Looks great and cost about $21.
Old 07-30-2013, 08:47 PM   #4
D Davis's Avatar
Trailer: u-haul ct13
Virginia
Ditto Donna!
A Twin Deep Pocket Jersy is the way to go bar none!!!! Just discovered it myself.
D Davis is offline   Reply With Quote
Old 07-31-2013, 01:27 AM   #5
Trailer: Casita 2001 spirit
Just when I was getting to the sheet problem you guys came thru as usual - Jersey Sheerts - who knew
Elaine
partslady9 is offline   Reply With Quote
Old 07-31-2013, 06:56 AM   #6
Trailer: 2015 Escape
Don't like jersey. We've used flannel sheets year around both home and in trailers for many years. Better when humid in the summer because they don't get that "clammy" feel.
Old 07-31-2013, 07:32 AM   #7
Jon Vermilye's Avatar
Trailer: 2017 Escape 21
Oswego, NY
I have an Escape 17B with a 48" X 77" rear bed. I found 3/4 sheets at Amazon that are a good fit. The bottom is a standard fitted sheet, while the top sheet has elastic in the bottom, making it easier to keep tucked in.
Old 07-31-2013, 11:58 AM   #8
Anyone use fleese sheets? Our first camping trip was in a thunder storm, and the trailer was damp. I am thinking fleese would be great as it would not be effected by dampness.
Do any other sheets offer this dry feeling as well in wet conditions?
Nelmes is offline   Reply With Quote
Old 07-31-2013, 12:10 PM   #9
Trailer: Scamp 16' Delux
We found a full size fitted although a little big worked fine.
Murphy C. is offline   Reply With Quote
Old 07-31-2013, 07:31 PM   #10
Saskatchewan
I chose flannel sheets and bought a pair of queen size with a pair of pillow cases. The flat one I sewed up like a pillow case and put the memory foam inside. The excess from the end made another pillow case. The fitted one yielded enough material to do the same thing for the front bunk. Works fine for us - we sleep under a fleece blankie or one or two sleeping bags depending on the weather.
Hazel in Sk is offline   Reply With Quote
SHEETS TO FIT CAMPER BED Karalyn Care and Feeding of Molded Fiberglass Trailers 7 05-29-2009 07:29 PM
Casita Fitted Sheets Donna D. Modifications, Alterations and Updates 20 11-21-2008 09:50 PM
Saran Disposable Cutting Sheets Legacy Posts General Chat 6 07-08-2003 08:58 PM
