Shelf weight - Fiberglass RV
Old 11-28-2012, 11:10 AM   #1
Sue and Henry's Avatar
Name: Sue and Greg
Trailer: 1982 Burro 13 foot and a 2015 Casita Spitit Deluxe 17 ft.
I'm making a shelf over the front window of my 13 foot burro.
This is what I have so far. There are three layers of cloth fiberglassed on the top and bottom of a 1/4" sheet of board (repurposed from an old waterbed base). The burro manual does not say what their shelf is made out of, but my plan is to fiberglass a front lip on and after finishing the surfaces, fiberglass it in place.
Picking this up in its unfinished state, it seems too heavy. My scale tells me it is currently 14#. Add another pound for finishing glass.
I plan to store clothes, extra bedding, towels...on top. Not the heavy stuff. Does this seem reasonable? Should the wall be strong enough?
Sue and Henry is offline   Reply With Quote
Old 11-28-2012, 05:09 PM   #2
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
I think that the walls are strong enough, but the shelf itself seems unnecessarily heavy. I'm also working on a set of similar shelves but I'm using 3/16" underlayment and extruded L shaped aluminum.
By giving a shelf "section" via an upturned portion you can gain a lot of strength with little weight. Sort of the way a piece of angle iron is much stronger than a a flat piece of steel of the same weight.
Old 11-28-2012, 05:24 PM   #3
honda03842's Avatar
Name: Norm and Ginny
Cabinet weight
I made our rear cabinet out of a sheet of 1/4 inch birch plywood, probably using less than half a sheet. The rear cabinet holds 3 blankets, two sets of sheets, all our jeans and holds up our 19" TV. It is supported off the window frames.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 11-28-2012, 05:27 PM   #4
Name: Sue and Greg
That is really attractive. I especially like that it is closed. I had planned open with a lip. Hum. Time to reconsider.
Old 11-28-2012, 05:31 PM   #5
Thomas G.'s Avatar
...... It is supported off the window frames.
My design also is supported off the rear window frame plus the side curtain attachment screws. Having a smooth interior like the Burro, I didn't want to do anything to the fiberglass that was permanent.
Old 11-28-2012, 05:32 PM   #6
Name: Sue and Greg
By section, do you mean the shelf is divided up bridging the short crossways? What about that long 5 1/2 foot length? How are you keeping it from sagging?
Old 11-28-2012, 05:36 PM   #7
Name: Sue and Greg
I see. Sounds like a very good plan. Thanks Thomas.
Old 11-28-2012, 05:50 PM   #8
honda03842's Avatar
Back or Front Shelf
Sue my shelf is supported off the side and rear windows. It required no holes thru the shell of the trailer. Unfortunately the side windows and rear window are not at the same height so I had to add a piece of wood to the top of the side windows to support the sides of the shelf. I'm going to look for a picture for you.
I used three pieces of aluminum angle to support the shelf, one for each window. I drilled holes in the angle that aligned with the window's screw holes and used these screws to hold the angle. I painted the angle black to match the window frames.
I first made the bottom and then glued a 1 x 3 to the front edge of the bottom. Then added the verticals and a cross member between the verticals. The verticals are to strengthen the area around the openings. Finally I added the front all screwed and glued together. It's very strong. I believe I described it in Preparing a 1991 Scamp under Modifications.
Since I added a piece of wood to even out the window heights, I added small shelves on each side. Besides providing storage space for little things, It also prevents the shelf from moving forward.
After thought... I probably glued the verticals to the face piece before installing it.
If you want more detail let me know.
By the way the height of the front face maes a pretty strong section.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 11-28-2012, 07:02 PM   #9
Thomas G.'s Avatar
No, section is an engineering term referring to the cross sectional dimensions of the structural piece. By having a relatively tall aluminum lip on the front, my design gives the long front piece a lot of resistance to sagging. I found this extruded stuff at a recyclers, but one could use aluminum angle from a place like Home Depot or Lowes. In Norm's design the front to the cabinet provides section to resist sagging..
Old 11-28-2012, 08:40 PM   #10
Name: Sue and Greg
Got it. Time for yet another trip to Home Depot. I'm putting their kids through college! Not a bad thing. : )
Old 11-30-2012, 03:24 PM   #11
Thomas G.'s Avatar
I'm at a point where I can post a few pictures of my shelf project instead of virtually waving my arms. I added a shelf to each end of the trailer with two side shelves in back and one short side shelf in front. Each shelf is made from 3/16" underlayment painted with exterior gloss paint to match the interior color. The aluminum is extruded in an L shape. Rather than drill holes, I attached to the window clamp ring, existing screws, or attached brackets with 3M Extreme double faced tape. The next step is to cover the screws to prevent snags and add a shock cord at mid level to hold things securely on the shelves. I may steal Raz's idea and add a mesh curtain to the shock cord.
Old 11-30-2012, 03:39 PM   #12
Name: Sue and Greg
Your shelves look great Thomas. I just returned from Home Depot with thin plywood to replace the 14# sheet. I am still going to skin the new one with a couple layers of fiberglass to stiffen it up a bit then put on a layer of gel coat since I already have it to match.
Old 11-30-2012, 04:37 PM   #13
Thomas G.'s Avatar
Thanks. If you are fiber-glassing over, the plywood itself doesn't add much strength, mostly weight. Sort of like an I beam, all the strength is in the top and bottom surfaces. Things like boats and surf boards are made of fiberglass over a foam core. But at any rate, a thinner board and aluminum angle should save you a lot of weight and be stronger, too.
Old 11-30-2012, 05:11 PM   #14
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
If you're fiberglassing anyway, and worried about weight, use honeycomb.
Tongue weight or hitch weight Cathi Towing, Hitching, Axles and Running Gear 26 04-23-2012 11:38 PM
help - I am interested in buying a small, light weight trailer- total weight 2000 pdd pwedd Hi, I am.... 19 07-23-2011 12:50 AM
How much weight could a shelf hold in a Scamp closet? Bryan L. Problem Solving | Owners Helping Owners 7 06-03-2009 09:50 PM
Tow weight vs vehicle weight Paula Bindrich Towing, Hitching, Axles and Running Gear 20 06-21-2007 08:16 PM
Tow Weight/Tongue Weight Legacy Posts Towing, Hitching, Axles and Running Gear 7 11-29-2002 08:49 PM
