shocks - Fiberglass RV
Old 09-02-2013, 08:29 PM   #1
gdo
Trailer: scamp
Iowa
shocks
has any scamp fifth wheel owners put shocks on to stop the bounce?
gdo is offline   Reply With Quote
Old 09-02-2013, 09:39 PM   #2
Trailer: asdf
Alabama
Not me but I want to.
jwcolby54 is offline   Reply With Quote
Old 09-03-2013, 06:00 AM   #3
cpaharley2008's Avatar
they have 5th wheel hitches with shocks that help with the connection, but if the unit has torsion axles, shocks are normally not used, they are saved for spring set ups.
Jim
Never in doubt, often wrong
Old 09-03-2013, 09:07 PM   #4
Brian B-P's Avatar
they have 5th wheel hitches with shocks that help with the connection...
Too bad the Scamp 19 is not a fifth-wheel... but that's another recent contentious issue.
... if the unit has torsion axles, shocks are normally not used, they are saved for spring set ups.
Although rubber suspensions are better damped than leaf-spring suspensions, and so shocks are more needed and thus more commonly added to leaf-spring systems, there are lots of shocks on "rubber torsion" suspensions. Airstream has used "rubber torsion" axles exclusively for decades (and are currently using Dexter's Torflex), and they put shocks on them as standard equipment.
Although European rubber torsion trailer suspensions have shocks available as optional equipment, they are generally not sold here. Since Monroe discontinued their bolt-on shock absorber retrofit kit, adding shocks to North American rubber suspensions has been a custom fabrication exercise... which has been done by some FiberglassRV members.
Trailer Shock Absorbers
Originally Posted by Donna D. View Post
I've personal seen three trailers with torsion axles and shock absorbers. Larry Page's Scamp 5er, Gene Layton's 17' Casita and Merle Lilly's Scamp 5er with dual axles. See the picture of Merle's in the third page of this PDF: http://www.fiberglassrv.com/forums/d...mAxleSetup.pdf
Old 09-03-2013, 09:12 PM   #5
Brian B-P's Avatar
It is possible that the rubber in the Scamp's suspension is worn out, and that with a new suspension (axle) the bounce would be substantially reduced, even without shocks.
Old 09-04-2013, 01:47 AM   #6
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
Mine doesn't have much trouble with bounce, but I have a new axle and a fifth wheel hitch with poly shock absorbers.
Old 09-04-2013, 11:19 AM   #7
Brian B-P's Avatar
Originally Posted by Jared J View Post
... I have a new axle and a fifth wheel hitch with poly shock absorbers.
Although a stock Scamp 19 is not a fifth-wheel, Jared's trailer is.
Old 09-04-2013, 11:44 AM   #8
Jared J's Avatar
Kansas
Sorry, should have mentioned that. I also keep my trailer tires at 60 psi, so it would ride even better with less.
Air shocks for Ford Ranger 15rms123 Towing, Hitching, Axles and Running Gear 9 09-19-2012 12:05 PM
bounce... could it be bad tug shocks? Scott S. Care and Feeding of Molded Fiberglass Trailers 15 10-07-2008 05:46 PM
air shocks sherry loving o Modifications, Alterations and Updates 12 09-14-2008 11:01 PM
New shocks, springs- What do I need? Denise K Towing, Hitching, Axles and Running Gear 3 02-08-2007 01:40 PM
bounce... could it be bad tug shocks? Scott S. Towing, Hitching, Axles and Running Gear 0 01-01-1970 12:00 AM
