Shore Power master fuse? - Fiberglass RV
Old 07-25-2012, 10:00 AM   #1
Trailer: Scamp 16 ft 2008
Got back from Oregon Gathering, went out to turn on the elect.fridge to get it cold for the next outing. Power cord from house is ok, breakers are ok in 2006 Scamp 16' but no joy!!
There is no power to the trailer from the 30amp cord into the converter box.
It was a rough ride down from Oregon - took Hwy 1 to Bodega Bay.
Any suggestions?
barbflynn is offline   Reply With Quote
Old 07-25-2012, 11:49 AM   #2
Not sure what converter you have but mine has a number of fuses hidden inside of it. Had to unscrew the top off of it to find them.
Old 07-25-2012, 04:29 PM   #3
Trailer: none
110 power or 12 volt.........shouldnt need converter for 110 volt....check outlet that refrigeration is plugged into if 110, on my scamp they just used the push in connections on the outlet and when working on it my radio would cut in/out, redid connection on outlet
Hambone is offline   Reply With Quote
Old 07-25-2012, 04:59 PM   #4
Raz
Raz's Avatar
Vermont
Are you plugged into a GFI outlet that might have tripped? Raz
Old 07-25-2012, 08:51 PM   #5
Barb,
Are you saying you checked for voltage at the 30a cord entry into the converter? If no voltage is there you have a cord or cord receptacle problem. If you have a voltage tick tool (makes noise when voltage is present) You can follow the voltage into the trailer and down the line. It won't tell you if the neutral is open though.
Russ
Shore-power connector replaces pull-out cord peterh Modifications, Alterations and Updates 72 12-18-2016 12:43 PM
76' Surfside - Does the battey charge when shore power is plugged in? dannis Problem Solving | Owners Helping Owners 2 05-26-2012 07:36 AM
A Question About Shore Power Red-Dwarf Problem Solving | Owners Helping Owners 10 03-21-2012 04:20 PM
Converter makes noise when in shore power Tezha Problem Solving | Owners Helping Owners 9 10-13-2010 02:52 PM
Wagon Master Furnace Dave Mc Classified Archives 17 06-08-2009 08:02 PM
