Short rigid shell awnings - seeking source - Fiberglass RV
Old 07-15-2018, 11:41 AM   #1
Davie B's Avatar
Trailer: Lite House
Question Short rigid shell awnings - seeking source
I have a very tiny LiteHouse Trailer for 2. It currently has a Carefree of Colorado bag awning. The canopy is about 75" wide.
The awning is in OK shape for it's age but getting the awning back in the bag, and getting the zippers to work is becoming more of a PITA. I can probably find a replacement bag canopy, but on a recent trip, I saw a small camper with a hardshell case for the rolled up canopy.
Does anyone know of a source for a hardshell canopy of this approximate size?
Davie B is offline   Reply With Quote
Old 07-15-2018, 02:12 PM   #2
Shady Boy might be worth a look. The case is around 4' long, so you could use it on the side or the back. It opens out to 10'x6' and weighs only 14#.
The Awning – Shady Boy Trailer Awnings
Old 07-15-2018, 03:33 PM   #3
Trailer: 2008 Casita 17 SD
I completely cut off the "bag" part and now I just slide the awning's Keder welt into the track, sans bag. When I'm done, I just slide it out, fold it up and stow it. Takes up much less room and weighs less when "set free" from the bag.
Old 07-15-2018, 04:59 PM   #4
Trailer: 1979 Boler 1300 / 1991 Casita Freedom Deluxe
Maine
I took of my carefree awning of the same size due to the end of the bag starting to rip. I replaced it with an 8 foot long Dometic awning. I had to take off the old rail and order an new rail with a 90 degree angle because the Dometic awning hung down a lot lower then the carefree and had to be installed further up on roof.
Also this awning went over the front and back curve of the Boler by about 3 inches but I just let it hang over into the air.
Instead of just a rivet in the last hole I could attach to the fiberglass I used a 1/4 bolt with a Fender washer on the inside toped off with an acorn nut.
Works great.
Old 07-15-2018, 05:21 PM   #5
mszabo's Avatar
Trailer: 1986 Bigfoot FT20
Carefree will repair or replace your bag. They are great to work with. Call them first, It will save you a bunch of money.
awning
Solar panel choices, flexible or rigid? Tony M Problem Solving | Owners Helping Owners 12 02-03-2018 11:08 AM
Rigid foam cabinets? Patricia D. Modifications, Alterations and Updates 24 11-14-2016 08:06 AM
Coroplast/Rigid Foam for Floor Insulation Evan Friesen Modifications, Alterations and Updates 14 05-30-2013 10:52 AM
Rigid Spare Tire Cover Supplier? js73751 Problem Solving | Owners Helping Owners 7 05-25-2009 07:44 AM
Flexible or rigid for offroad use. (78 Scamp trailer) Coach George Jessup Care and Feeding of Molded Fiberglass Trailers 22 05-07-2006 01:52 PM
