Should have something between the two layers of the FG door - Fiberglass RV
Go Back   Fiberglass RV > Maintenance | Restoration | Modifications | Problem Solving > Problem Solving | Owners Helping Owners
Click Here to Login
Old 05-25-2016, 11:44 PM   #1
Hi, somewhere I noticed someone said there is wood between the two layers of the fiberglass door. I found nothing inside mine,and wonder if I should put something inside to connect the two layers.
Thank you in advance for any comments/suggestions.
HawkBoler72 is offline   Reply With Quote
Old 05-26-2016, 05:02 AM   #2
Johnny M's Avatar
Deep South
My 71 Boler door was original and had wood slats inside which had turned to a mushy pulp from years of water leakage in around the window. It was also very heavy from being water logged and a PO's weep hole at the bottom didn't do much good. I removed all the pulp and replaced it with 1" styrofoam insulation cut to fit (much lighter now) Another factory could have used something different inside or perhaps nothing at all, but with yours only a year older than mine, a PO could have rebuilt it and left an empty void. I also added a hand bend metal tube frame epoxied to the inside of the outer layer of fiberglass to help retain its curved shape. In hindsight, the only thing I can suggest that I would do different is to take more time to preserve the inner fiberglass skin by trying to separate the two layers as opposed to cutting it apart, I ended up remaking an inner skin using the outside as a mold covered in wax paper.
Old 06-04-2016, 09:47 PM   #3
I filled in some Window & Door Insulating Foam, as shown in the attached picture.
Old 06-05-2016, 06:50 AM   #4
I used the same foam to fix the door on a small refrigerator .
Has held up for about 10 years. You want the foam shown in the picture , not the triple expanding foam and don't expect to get the door apart after the foam dries
Old 03-05-2017, 04:55 PM   #5
Trailer: Scamp - "The Haunted Mansion" (13') and TBD (16')
The process you used was very similar to what we did... Our door was full of rotten mush...We scraped it out and replaced it with a metal tube frame filled with foam insulation except for where the lock was. The final inside cover was simply cardboard which we then fiberglassed over. Works great for us!Click image for larger version
ID:	103494Click image for larger version
Sohkraites is offline   Reply With Quote
Should I have said something? SRD General Chat 22 02-27-2014 02:09 PM
"Between every two pines is a doorway to a new world." — John Muir Adrian W General Chat 3 05-15-2011 03:01 PM
A tale of two jerks and two generators Legacy Posts General Chat 36 07-19-2003 02:55 PM
Something you should know... General Chat 0 01-01-1970 12:00 AM
» Trailer Showcase
Pokemon
Norm W
William
Liessi
