Shower? - Fiberglass RV
Old 09-05-2007, 10:29 PM   #1
FRED SMAILES's Avatar
Trailer: 13 ft Boler
Kootenay's of BC
We have a 13 ft Boler. We live in BC Canada and do most
of our camping here. We love the beautiful parks that are
around about every corner!
BUT I GOTTA HAVE A SHOWER!
My plan is to get a Coleman hot water on demand.
Attach a Hulla Hoop to the closet and the overhead cupboard
to hold 2 cheap shower curtains
and mount the shower head to the roof screen knob.
Use the Rubbermaid container that holds gear when we're are
on the road to stand in, and put a drain in it to the portable gray tank that also holds the sink gray water.
My question : Does the Coleman Hot Water On Demand
do a good job?
Thanks in advance for your imput.
Fred
FRED SMAILES is offline   Reply With Quote
Old 09-05-2007, 10:59 PM   #2
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
yep. ....longer you leave the water cycling befor you use it the H O T T E R it gets!!!
Your plan sounds 'do-able' but some fellow campers MAY take a dim view of your process, but what t he hay????
Old 09-05-2007, 11:08 PM   #3
Greg A's Avatar
Trailer: 2015 Escape 19
One of the shower room tents at Wally is only like $30-$34.
Seems like it might be less trouble and more usable.
Owner:
Fiberglass-RV-4Sale.com
Scamp Owners International
Old 09-06-2007, 01:03 AM   #4
Trailer: 1975 Trillium 13 ft / Chevy Astrovan
I like the hula hoop idea!
Connie M. is offline   Reply With Quote
Old 09-06-2007, 01:05 AM   #5
And I like the idea of showering inside, where it is warm
Old 09-06-2007, 06:08 AM   #6
james kent's Avatar
Trailer: Boler 1984
That sounds like an awful lot of moisture inside the trailer even if you can contain it. How about this?
Old 09-06-2007, 08:35 AM   #7
Gina D.'s Avatar
West Coast USA
I did exactly what you are planning in my 13. I had hooks on the walls for the curtain, and used a coleman shower pump and a pan of hot water.. otherwise, identical.
Splashing and spillage is non existent if it's set up correctly. It does add water vapor, so you have to be aware if you have rat fur walls. With a burro, it was a non issue. I just wiped the walls down if it was a problem.
I didn't drain into anywhere, I just picked up the tub and dumped it by hand.
Old 09-06-2007, 09:29 AM   #8
Trailer: 73 Trillium
do a good job?
Fred
My thoughts are the same as yours. I have already purchased the coleman heater and I am presently working on a curtain holder made with cpvc pipe( can be disassembled). Plan to also make it mountable outside in some fashion( not sure how yet) for trips to wilderness areas. Certainly will use the inside method when temps cold and for campground privacy (eg. Walmart camping). Have thought about using a cooler as my storage/ stand in container(has drain built in); also could be the back-up for fridge when the temps rise to extremes. Have thought about moisture problems- will be installing a maxx fan in the future. As far as your question is concerned- I am happy with the trial( nice warm water).
Dave N. is offline   Reply With Quote
Old 09-17-2007, 04:52 PM   #9
Trailer: Scamp 13 ft
Try this.
1. Run hose from water tank drain to purchased 12v boat water pump
2. Hose from pump to rear bumper
3. Drill hole in pumper and install quick realeas hose attachement
4. Travel with coiled hose with adjustable nozel
This works PERFECTLY for our needs. No, its not a hot shower, but hey, you're camping!
LeBoutillier is offline   Reply With Quote
No shower> Add a shower Ken C Modifications, Alterations and Updates 9 09-01-2013 12:25 AM
Portable shower Kevin K General Chat 8 07-13-2010 08:18 PM
Looking for one with shower Missy H Wanted: Molded Fiberglass Travel Trailers 0 03-07-2009 11:02 AM
Shower Legacy Posts Rallies, Get-togethers, Molded Meets (Archive) 26 11-19-2002 05:21 PM
Shower?? Legacy Posts Problem Solving | Owners Helping Owners 43 11-16-2002 01:07 PM
Copyright ©2000 - 2018, vBulletin Solutions Inc.
