Old 06-08-2012, 06:30 PM   #1
Trailer: Biggar
Saskatchewan
shower drain in a Biggar plugged?
Hello, I was wondering if there is something besides a plugged drain that would stop water from draining out of the shower. Pretty sure it's plugged, but this is my first trailer and I am not wanting to force anything and end up costing myself big dollars in repair costs. Thanks, Stu.
Saskstu is offline   Reply With Quote
Old 06-08-2012, 06:33 PM   #2
Trailer: Bigfoot 21
is the tank empty? Only time I ever had water in the shower floor was when the grey tank was full....
Old 06-08-2012, 06:34 PM   #3
Trailer: Bigfoot 21
it posted twice!
Old 06-08-2012, 06:44 PM   #4
You sure you do not have a shower pump that needs to be turned on. many trailers have them. Switch on the wall of the bathroom some place??? Go under the trailer and look to see whats under the shower drain area - there may be a trap or a pump that needs cleaning.
Old 06-08-2012, 06:46 PM   #5
Trailer: Biggar
Saskatchewan
Gee, you guys are quick, I was hoping to finish my beer before I went back out to look. Tank is empty, I will look underneath and see what I find. Thannks, Stu
Old 06-09-2012, 08:43 AM   #6
Trailer: Biggar
Saskatchewan
Well, I couldn't find a pump or a switch for a pump and under the Biggar is all fibreglass so there wasn't much to see. I took a plunger to the drain and couldn't move any water at all, a snake is next I suppose. Thanks for the help. Stu
Old 06-09-2012, 08:46 AM   #7
Roy in TO's Avatar
What you see may depend on whether or not that was your first beer.
Old 06-09-2012, 09:13 AM   #8
Stu, is there no way of removing the shower drain from above?
If you dont have one yet a handy item to have which may or may not help in this situation but helps to give the tanks a real good rinse is a tank wand. It reaches into the tank and helps at getting dirt build up off the top, sides and bottom of the tanks.
Sorry we werent of much help on this one.
Old 06-09-2012, 12:37 PM   #9
Marinab's Avatar
Trailer: 1978 Biggar / 2007 Toyota Tundra V8 2wd
Stu, please post what you find out. I also have a Biggar but I haven't tried the shower yet, so don't know if it's working or not. Thanks, Marina
Marinab is offline   Reply With Quote
Old 06-09-2012, 01:05 PM   #10
Marina, didnt your trailer come with all the original manuals? Is there anything it it regarding the shower or a water pump for it?
Old 06-09-2012, 03:15 PM   #11
Lizbeth's Avatar
We had a shower that wouldn't drain and it was because the P trap had slipped and the drain pipe was running level so it wouldn't drain. Shoved it back into place and tightened... all better.
Old 06-10-2012, 11:39 AM   #12
Trailer: Biggar
Saskatchewan
Well, the beer was fine, only had one and didn't find much out till this morning. Seems the 3rd valve is just for the shower. Open the valve and the shower should drain...problem is, the gate valve is broken and I have to figure out how to fix that without ruining the rest of the plumbing. Thanks for all the help.
Old 06-10-2012, 01:11 PM   #13
The gate valve should have 4 screws on it making it fairly easy to remove and fix or replace.
Old 06-10-2012, 02:24 PM   #14
Trailer: Biggar
Saskatchewan
Carol, yup, 4 screws, but that is for the whole assembly, the one valve that was broken, is glued in place. I drilled a 1" hole on the side of valve body, below the gate, and pryed the gate down with a screw driver.I am going to try to glued the bar back to the gate later, I have to make pizzas now...wood fired pizza oven...fun and delicious. Have a great day
Stu
biggar
Shower Drain Check Valve Baj Problem Solving -- Owners Helping Owners 11 06-05-2011 03:01 PM
Shower Drain? Christi V. Problem Solving -- Owners Helping Owners 26 11-02-2010 10:17 PM
slow shower drain sean m Problem Solving -- Owners Helping Owners 2 02-14-2010 09:29 AM
E-Z Shower Drain Valve Extension Legacy Posts Problem Solving -- Owners Helping Owners 2 05-10-2003 08:03 AM
shower drain Legacy Posts Problem Solving -- Owners Helping Owners 8 10-02-2002 06:28 PM
the next 365 days.
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Close [X]
