Shower not draining - Fiberglass RV
Old 07-21-2007, 05:17 PM   #1
Brenda Ferrell's Avatar
Trailer: 2005 19 ft Scamp 19 ft 5th Wheel Deluxe / 2006 Tundra V8
Help Please
Shower will not drain. I can hear the pump running, but the water will not drain. It worked prior to last camping trip. Kitchen sink will drain; no problem. Any ideas or suggestions. Is there a filter underneath the camper that may be plugged? Have a Scamp 5r, 2005, Dlx with high lift axle. Thanks in advance.
Brenda Ferrell is offline   Reply With Quote
Old 07-21-2007, 08:25 PM   #2
Administrator
Mary F's Avatar
There is a valve that should be closed for transit (so you don't get back splash from the graywater tank) and opened for operation (shower draining).
It's accessed from outside, via a hard to reach handle that is located in the front of the Casita, just to the curb side of center, at the bottom, behind the propane tank(s).
You'll have to look for it the first time... Holler back if you can't find it.
Mary F Fiberglass Rules!
FGRV Forum Custom Search
Old 07-21-2007, 10:05 PM   #3
Trailer: 1998 17 ft Casita Spirit Deluxe / Red F150 X-Cab
Hey I just learned about that one this week too! Very important!
Lisa M. is offline   Reply With Quote
Old 07-22-2007, 04:32 AM   #4
Thanks for the replies Mary and Lisa, but I have a Scamp Fifthwheel; there is no handle to pull to drain the shower. The shower pan actually has a stopper, like your sink at home. I sold my Casita this spring and bought the Scamp to replace it. Guess I need to change my signature.
Old 07-22-2007, 07:13 AM   #5
Joe Z's Avatar
New River AZ
sounds like you may have a clog in the "P" trap under the shower...... put a little water in your shower until it comes up over the drain and use a good "rubber" plunger and you should be able to clear it out.......hope this helps.
Joe
Joe and Linda
2013 Casita SD
Dodge Ram 4x4
Old 07-22-2007, 07:53 AM   #6
Trailer: Scamp 19 ft 5th Wheel ('ye ole bucket')
Maybe the newer Scamps have ptraps but i think most of them have just a tube that runs from underneath the drain ( thru a filter) to the grey water tank.... Of course on my thread someone totally mickey-moused it and put the T in to drain the shower onto the ground... I am having to take it in to get replummed!!
Christine V is offline   Reply With Quote
Old 07-22-2007, 05:51 PM   #7
Joe Z's Avatar
New River AZ
Christine......
I don't know much about scamps but without a "P" trap in the shower how do they keep the smell of the grey tank from stinkin up the bathroom?? That's gotta be rough!
Joe
Joe and Linda
2013 Casita SD
Dodge Ram 4x4
Old 07-22-2007, 05:54 PM   #8
Administrator
Mary F's Avatar
Yeah, thanks, Brenda. For a second there you had me going! I could've sworn it said "Casita" beneath your avatar!
Good luck with it. I have no idea on a Scamp Fiver...
Old 07-22-2007, 07:44 PM   #9
ddayton's Avatar
Trailer: 2007 Casita 17 ft Spirit Deluxe
Send a message via Yahoo to ddayton
Help Please
Brenda, my 2005 Scamp 5vr shower/sink drain had a P trap, filter and water pump. If you can hear the the pump running, then the first thing I would check is the filter and then the P trap.
Good luck....Don
ddayton is offline   Reply With Quote
No shower> Add a shower Ken C Modifications, Alterations and Updates 9 09-01-2013 12:25 AM
Lowest inch while draining fresh water tank Cory Lewis Problem Solving | Owners Helping Owners 2 10-12-2009 11:29 PM
Shower? FRED SMAILES Problem Solving | Owners Helping Owners 8 09-17-2007 04:52 PM
Shower Legacy Posts Rallies, Get-togethers, Molded Meets (Archive) 26 11-19-2002 04:21 PM
Shower?? Legacy Posts Problem Solving | Owners Helping Owners 43 11-16-2002 12:07 PM
