Shower - Not Working - Fiberglass RV
Old 04-29-2017, 05:07 PM   #1
Trailer: ParkLiner
Virginia
I am getting my parkliner ready for a trip. It was still winterized, so I drained the antifreeze and filled the holding tank and lines with bleach/water.
The water pump works and I get water at the sink, the rear outside faucet, and the toilet. When I turn the shower on, I get water for a second or 2 and then nothing. Both hot and cold, same thing.
At first I thought the line or shower head might be clogged, but if that was the case I shouldn't get any water at all.
Any ideas?
Huck is offline   Reply With Quote
Old 04-29-2017, 05:54 PM   #2
Trailer: Escape 5.0 TA
W. Mass
I've had the shower mixer break on me when filled with antifreeze over the winter. In my case water was pouring out of it where it cracked as opposed to yours. Might pull the shower head off and try the shower again, if you still do not get water look at the mixer. The only things I can think of that are common for both hot and cold is the mixer, the hose, and the shower head. Of course I'm not a plumber.
Bob & Deb
padlin00 is offline   Reply With Quote
Old 04-30-2017, 09:04 AM   #3
Trailer: ParkLiner
Virginia
Found the problem. I took off the shower head and there was grit clogging the holes. Cleaned it out and shower works fine.
Then the kitchen faucet wouldn't work. Same problem and same solution.
I camped at several state parks in March and evidently at least one had grit in the water. My filter was leaking so I didn't use it. Lesson learned.
Old 04-30-2017, 10:13 AM   #4
kdhanso's Avatar
Trailer: Scamp 19 Deluxe & 16 STD
The grit is most likely calcium deposits
Ken
kdhanso is offline   Reply With Quote
Shower Pump Question (Empty shower pan in 5th Wheel Scamp) Gail Shook Plumbing | Systems and Fixtures 2 09-05-2013 11:59 AM
No shower> Add a shower Ken C Modifications, Alterations and Updates 9 09-01-2013 12:25 AM
Document Center Not Working? bobtrower Forum Admin, News & Announcements 4 05-04-2006 06:29 PM
Fridge not working all the time Karen Fisch Problem Solving | Owners Helping Owners 7 05-01-2006 07:25 AM
Personal Photo not working Rob S. Forum Admin, News & Announcements 5 01-15-2006 10:13 PM
