Silicone Removal ? - Fiberglass RV
Old 07-10-2011, 06:55 PM   #1
Trailer: 1991 17 ft Horizon
Silicone Removal ?
OK I have some projects ahead of me sometime this summer. One is silicone removal, a re-rivet job, and reset all of the windows. So I have to scrape some of this silicone off, now what does everyone use to clean up the fiberglass after scraping off what you can? I'm thinking denatured alcohol ? I did try a look through some older post, but didn't have any luck.
Old 07-10-2011, 07:30 PM   #2
Trailer: One 13 ft Scamp and One 13 ft Trillium and Two Trillium 4500
I just ran SCREAMING OUT THE DOOR!!!!!!!!!!!!
Randy Bishop is offline   Reply With Quote
Old 07-10-2011, 07:49 PM   #3
Silcone is the most GOD AWFUL stuff I've ever had to deal with.. I've redone more than 16 of these trailers and have removed a truckload of the stuff, the one I'm working on now has 198 tubes of the stuff on it..in some places it's over 2" deep and the only conclusion I've come up with is to scrape, scrape, scrape scrape and then sand, look where you sanded and you will be able to see the little traces of the DEVIL'S SEED left behind the sanding, so its back to scraping again because you can sand the stuff off you'll sand through the fiberglass before the silcone will turn loose..The only solvent I found is elbow greese..Good luck and try NOT to pull your hair out....
Old 07-10-2011, 08:00 PM   #4
Googone or it's equivalent seems to work very well for simple removal but if you want to paint , you might try polycracker after a thorough cleaning and before paint.
R & E Paint Supply. Polycracker , The Professional Prep Wash Solution
Old 07-10-2011, 08:08 PM   #5
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
Plastic scraper (pushed like a chisel and if you wish given a single-bevel edge like a chisel). Plastic laminate (Formica is the proprietary name everyone remembers) sawn up in say 2" x 4" tickets fit my hand pretty well. ScotchBrite and Bestine combine a slight abrasive and slight solvent action. Bestine is very volatile and not kind to brain cells but if you have more than 100 of those and only work on the exterior, you'll probably have a 75 left when you finish. Hint: When pushing that plastic "chisel" use a slight skewing action to sort of cut or sever the plastic salamander from its perch on the polyester.
jack
Old 07-10-2011, 08:16 PM   #6
Mine fortunately isn't that deep, looks to be only one layer around the windows, and on the rivets. I'm pulling the windows anyway so I'll tackle each window as I pull them out. And the rivets I'm replacing too so after I drill each one then I'll scape off any that's on around where the rivet was. I have seen trailers where it was really on thick, but this isn't the case, and I'm not planning on painting. The trailer is in very good shape and not used much by the previous owner. But the rear window did leak and I'm sure it was used as a quick fix.
Old 07-10-2011, 08:55 PM   #7
Jeff Johannsen's Avatar
Trailer: 1978 Trillium
It really ain't the thickness, it's the fact that it be there at all. On our trailer, the previous owner seemed to have stock in the company that makes this stuff. If the glass is smooth, I carefully scrape with a razor blade then rub my dirty hands on it and bingo, it's still there. Repeat. Then repeat. Then repeat. Then repeat. Then repeat.Then repeat.Then repeat.Then repeat.Then repeat.Then repeat.Then repeat.Then repeat.Then repeat.Then repeat.Then repeat.
Jeff Johannsen is offline   Reply With Quote
Old 07-11-2011, 03:56 AM   #8
Sharon G's Avatar
Trailer: Aliner
Floyd, I just took a look at your link. I had never heard of that product. Sure would have loved to have it for some previous projects I struggled with.
I've got it bookmarked for future reference. Thanks!
Sharon G is offline   Reply With Quote
Old 07-11-2011, 05:03 AM   #9
Thanks everyone for the comments suggestions , Floyd that's the stuff I was really looking for. I'm not planning on painting but I'll probably use polycracker just the same to get the silicone film off the fiberglass.
Old 07-11-2011, 01:42 PM   #10
LukeP's Avatar
I'll second Goo Gone, to doing a pretty good job. Takes off that nasty film that is so hard to get rid of. Hopefully it's not doing anything worse to the paint, but I can't find anything else that works as well.
LukeP is offline   Reply With Quote
Old 07-11-2011, 03:06 PM   #11
Thanks Luke, I will try that first and that may be all I need. But if I need something more I'll go with the polycracker and I can get it local. Thanks to Floyd for that recommendation .
Old 07-11-2011, 03:36 PM   #12
You've got to "think" the silicone is gone before you use the Polycracker. It really only removes or neutralizes the silicone which is "soaked in" to the gelcoat, so that you could clean, wax or paint the cleaned surface.
Old 07-11-2011, 04:00 PM   #13
Got it . Thanks
Old 07-12-2011, 11:11 AM   #14
Trailer: 2009 17 ft Eggcamper / Chevy S-10
I just did a quick Google search for "silicone removal" and both McKanica and DOW make removal compounds. Have any of you tried these (or similar) commercial products?
71 Boler 13' Floor Removal/ Shell removal mikeandmadi Problem Solving | Owners Helping Owners 1 05-23-2011 10:28 AM
Why not Silicone? melissab Problem Solving | Owners Helping Owners 17 09-19-2010 10:57 AM
Removing silicone! Crystal, Huscroft Care and Feeding of Molded Fiberglass Trailers 30 07-28-2009 10:38 AM
Silicone VS Vulkem VS ?? Kevin Problem Solving | Owners Helping Owners 9 01-01-2008 08:04 AM
Help with silicone removal John Perry Care and Feeding of Molded Fiberglass Trailers 30 10-06-2006 09:25 AM
