Silicone Remover? - Page 5 - Fiberglass RV
Old 01-06-2013, 12:13 PM   #57
Name: Steve and Rosemary
Utah
Great thread! I'll take photos but trust me, the amount of silicone on our Scamp (in and out) is INSANE! Two questions:
1. Did anyone try it inside? Results?
2. What should I use instead? I guess the belly band needs something but I would like to use something, anything but silicone.
Love this forum!
SERENITY 1989 Scamp 16' Side Toilet | Steve, Rosemary, Maude Pod & Tripawd Hope | Next trip: The Weber for some fishing
Moab Maiden Voyage 03/10 * The Swell 5/26/11 * Antelope Island 12/31/11 * Strawberry Res 6/12 * Whitney Res 6/14 * Uintahs 07/15 * East Fork of Black's 06/16
Steve and Rosemary is online now   Reply With Quote
Old 01-06-2013, 01:03 PM   #58
Mark J's Avatar
Trailer: 13 ft Scamp 1999
Originally Posted by Steve and Rosemary View Post
Great thread! I guess the belly band needs something but I would like to use something, anything but silicone.
I have been s l o w l y remvoving silicone. Does the belly band need resealing after removal or can it just be left "naked"?!
Oh, and how do u really select quotes? (I know my ignorance is showing-)
Mark J is offline   Reply With Quote
Old 01-06-2013, 01:18 PM   #59
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
You need to make sure the [and ] brackets are intact when you shorten a quote.
Old 01-06-2013, 02:09 PM   #60
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
Mark, I just added the /[ back in front of the ending this QUOTE] at the end of the quote you made.
Basically when you quote someone, and remove some irrelevant parts to keep it simple, you must make certain you leave the [QUOTE] [/QUOTE] BB code tags intact on each end.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 01-07-2013, 10:06 AM   #61
Trailer: 77 Scamp 13
I removed belly band on my scamp over the summer. Belly band "should" be cosmetic, not a seal. The top and bottom half of the shell are fiberglassed together on the inside to seal. The belly band just covers the ragged lip of the top and bottom pieces for looks. BUT.... my belly seam did have a small leak I found using a watering can so I removed the band and caulked and coated the seam under the band using adhesive marine caulk.
Replaced the band after the caulk was fully dry and set.
I think it was easier to get all the old caulk cleaned up with the band off so once I had enough caulk off to remove band that is what I did.
It was pretty easy to remove belly band, and easy to polish belly band while off, did have a couple of rivets sort of hidden in the door frame that needed to be removed. Band ends in a tab in the door frame.
Oh and it's a good idea to put a couple layers of masking tape on the side of the rivet gun when you rivet the band back on. To keep the side of the rivet gun from scratching the side of the camper.
Some people put a small bead of caulk along the top of the belly band to keep dirt from accumulating in that seam. Not sure the best caulk to use for that. Do know you don't want to do it on a hot sunny day because the caulk sets too fast (don't ask!)
Old 07-07-2013, 11:00 AM   #62
Utah
I hate to beat a dead horse but we're going to look for some DAP and we're wondering what's best to use in its place. Most of our rivet caps and the plastic pieces they snap to are destroyed by sun. We don't want to re-rivet the whole thing just for this and thought we could just "glue" the caps over the rivets. Any suggestion on what we should use would be much appreciated. Is rubber butyl the most common choice?
Old 08-07-2013, 01:58 PM   #63
Trailer: Fiber Stream
Maryland
DAP - Silicone-Be-Gone - Gone
Just confirmed with the company here in Baltimore that this product is discontinued and any remaining on shelves at this point should not be sold because it would be out-of-date by a number of years.
Dave in Baltimore "DAP CITY"
JD1994 is offline   Reply With Quote
Old 08-07-2013, 03:53 PM   #64
D Davis's Avatar
Trailer: u-haul ct13
Virginia
I think "silicone- be- gone" is the best remover. Have used it after many other products on a mountain of old Silicon and glue. It must sit for a while before scraping it off. I found it on Ebay. They do not sell it anymore in the big box stores. Even if it's old it works, at least the two bottles I bought did.
D Davis is offline   Reply With Quote
Old 08-07-2013, 04:09 PM   #65
Thomas G.'s Avatar
I read on a DIY forum that one can mix mineral spirits with talcum powder to make a paste, apply it to the silicone, then cover with plastic wrap. I have not tried it.
Old 08-07-2013, 07:41 PM   #66
SOMEONE has to try this!!!!!!!!!!!!!! Please, please, please let ALL of us know how it works MOST of us aren't looking for an instant solution, just SOMETHING that works!
Old 08-08-2013, 10:00 AM   #67
Thomas G.'s Avatar
This was posted by a chemist.
It assumes that you have removed as much silicone as possible with a sharp piece of plastic. Evidently they actually make plastic razor blades for this kind of work.
Old 08-08-2013, 06:10 PM   #68
I understand why you want to glue them on... I'd use:
Proflex caulking sealer
Old 08-08-2013, 07:13 PM   #69
Brian B-P's Avatar
Yes, they do...
Plastic Scraper for Fiberglass
Brian B-P is online now   Reply With Quote
Old 08-11-2013, 11:11 AM   #70
Utah
I've had trouble finding the DAP, even on eBay but it looks like a place in Canada called Canadian Tire may have it available. Anyone up north willing to buy a few bottles to send to a friendly (and ever so THANKFUL) neighbor to the south?
In other news, I tried the McKanica Silicone Caulk Remover Gel and it definitely softens some types of caulk a little but doesn't have a mind blowing effect. We have some more on there now to see if maybe I didn't apply it liberally enough....
If anyone would be willing to pick up some DAP for me, the Canadian Tire product number is 67-0809-0.
Good Rust Remover for Fiberglass? Pamela S. Problem Solving | Owners Helping Owners 24 01-08-2013 06:49 PM
black streak remover Laura June Care and Feeding of Molded Fiberglass Trailers 5 06-22-2012 07:00 PM
Foam Insulation/Sealant Remover BruceG Problem Solving | Owners Helping Owners 3 05-23-2012 08:51 PM
Smell remover Rands E. Problem Solving | Owners Helping Owners 7 04-02-2008 06:35 AM
Bear Remover Bill Abbay Jokes, Stories & Tall Tales 2 03-03-2006 11:21 PM
