Silicone Remover? - Page 6 - Fiberglass RV
Old 08-11-2013, 11:15 AM   #71
You can buy it on-line, can't you? CT should ship.
Old 08-11-2013, 11:20 AM   #72
Name: Steve and Rosemary
Utah
I thought I'd try that but I didn't see a way to add to a cart. I'll look again. Thanks for the tip.
SERENITY 1989 Scamp 16' Side Toilet | Steve, Rosemary, Maude Pod & Tripawd Hope | Next trip: The Weber for some fishing
Moab Maiden Voyage 03/10 * The Swell 5/26/11 * Antelope Island 12/31/11 * Strawberry Res 6/12 * Whitney Res 6/14 * Uintahs 07/15 * East Fork of Black's 06/16
Steve and Rosemary is offline   Reply With Quote
Old 08-11-2013, 11:22 AM   #73
Trailer: 17b Escape
Goo Gone will remove silicone.
J Mac is offline   Reply With Quote
Old 08-11-2013, 11:30 AM   #74
Utah
Just called their hot line and the gentleman I spoke with said that online purchases will not be possible for a few months. He also could not take and order over the phone so I'm left with calling a store. The only problem might be that they can't ship/sell to the States. Any thoughts on this?
Old 08-11-2013, 11:49 AM   #75
Utah
Called a store in Calgary and the manager is going to try to work something out on Tuesday. The problem is that they don't really have a way to accept payment except in person. She's thinking I could fax my DL to her for proof that I am who I say I am. Anyways, I'll keep everyone posted as to my level of success.
Old 08-13-2013, 10:34 AM   #76
Utah
Thanks for the tip -- I'll look into getting some of that!
Old 08-13-2013, 12:06 PM   #77
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Please report back on your findings.
Thomas G. is online now   Reply With Quote
Old 08-13-2013, 07:25 PM   #78
Yes, we want to know if you find Go Gone to be helpful. It didn't work for me. I think I've tried every "normal" chemical known to man. Everything from acetone to WD40 to mineral spirits ...
Old 08-13-2013, 07:42 PM   #79
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
I have successfully used Goof Off (or Goo Gone, just another brand) to remove silicone residue. We have to do this a lot when recaulking bathtubs and other fixtures. You do first have to remove as much as possible without damaging the substrate, but you smear in on, and a short while later go at it and rub the residue off with a clean cloth (not paper towel).
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 08-14-2013, 08:35 PM   #80
Trailer: 17b Escape
I usually drape paper towel over silicone residue after removing as much as possible without scratching. Then I wet the towel with Goo Gone and let it sit for several mins. It will remove in time.
Goof Off and Goo Gone contain different contents. Goof Off may contain thinners. Goo Gone is just citrus. I'd stick with citrus.
Old 08-15-2013, 12:28 AM   #81
Trailer: 2008 13' Scamp
I usually scrape the bulk of it off then use Tumbler with a scrubbie. I've been using it for over 20 years with great results. When I paint over an area that was contaminated with silicone and the paint goes on without any problem it must have done a pretty good job at removing traces of silicone.
I also routinely use it to wipe down anything that I'm going to paint.
Old 08-15-2013, 11:42 PM   #82
Utah
On a side note, I know I've read the reasons but can someone condense them into a short list why we should prefer to use butyl rubber instead of silicone products to redo the beads?
Old 08-16-2013, 05:40 AM   #83
..but can someone condense them into a short list why we should prefer to use butyl rubber instead of silicone products to redo the beads?
Short list? How about:
Silicone is a temporary fix that can turn into a permanent problem!
Nothing sticks to silicone, except silicone.
So... that means... once it is used... unless you get it ALL off, you'll continue to have problems.
Paint and silicone don't mix. A trailer that has had silicone applied, will need special care to prevent fish eye in the paint.
And on and on and on....
Old 09-05-2013, 08:35 PM   #84
Trailer: 2010 Escape 17B
Steve and Rosemary - please check your PM and respond, thanks.
kootenaigirl is offline   Reply With Quote
Good Rust Remover for Fiberglass? Pamela S. Problem Solving | Owners Helping Owners 24 01-08-2013 06:49 PM
black streak remover Laura June Care and Feeding of Molded Fiberglass Trailers 5 06-22-2012 07:00 PM
Foam Insulation/Sealant Remover BruceG Problem Solving | Owners Helping Owners 3 05-23-2012 08:51 PM
Smell remover Rands E. Problem Solving | Owners Helping Owners 7 04-02-2008 06:35 AM
Bear Remover Bill Abbay Jokes, Stories & Tall Tales 2 03-03-2006 11:21 PM
