Silicone VS Vulkem VS ?? - Fiberglass RV
Old 12-29-2007, 03:05 PM   #1
Kevin's Avatar
Trailer: Scamp 16 ft
Is White Silicone the preferred sealant for a FG Trailer? How does it compare to Vulkem and is there some places that one is preferred over another? I have another post where I have a delta antenna leaking. Removed and reinstalled with white silicone. Still leaking. Should I try again with Vulkem or is it as good or the same?? Thanks
Kevin is offline   Reply With Quote
Old 12-29-2007, 03:38 PM   #2
Trailer: 1977 Boler 17 ft
Can you give us a picture of what you're working on? Is there any way you can use butyl to seal it? By butyl I mean the tape you use to seal windows etc. I have used it many places with sucess if there is enough surface for it to seal on.
Neil W' is offline   Reply With Quote
Old 12-29-2007, 04:23 PM   #3
Never Silicone!
Check out this great topic, lots of good info:
Butyle Tape, Silicone and sealing
Old 12-29-2007, 05:18 PM   #4
Kevin's Avatar
WOw!! didn't know that. I will pull it and reseal it with the tape. The next question would be the belly band on the Scamp. Since that can't be done with tape, how whould that be done?
Never Silicone!
Old 12-29-2007, 05:19 PM   #5
Kevin's Avatar
Also, the scamp has all the little screws and buttons on the outside that the previous owner said he used silicone on. A dab at each fastener. WHat type of sealant for that? Thanks
Old 12-29-2007, 06:03 PM   #6
Kevin's Avatar
OK, after reading the entire post on sealing I see that the Butyl tape seems to be the best. There is also some marine grade sealant recommended in there also. The Delta Antenna manufacturer recommends Vulkem, so thats what is confusing.
Old 12-29-2007, 06:45 PM   #7
Greg A's Avatar
Trailer: 2015 Escape 19
I use the 3M Marine sealant I believe it is the 5200 at Wally in the marine section.
Excellent stuff.
Owner:
Fiberglass-RV-4Sale.com
Scamp Owners International
Old 12-31-2007, 08:58 PM   #8
Ed Harris's Avatar
I have talked to a friend who is a roofer and it seems that Vulcam is Butyl Rubber.
It is just a slightly different consistency and in a tube usually not in strips.
Just some info for what it may be worth.
I know when installing Sat.dishes on roofs I have used them interchangebly.The wide butyl pads are referred to in that applications as "Pitch Pads" and are just butyl in a large format with the release paper on both sides.
Using Vulcam is the messiest most unforgiving task I think I have ever done,but it will not leak either.
Come to think of it Butyl in any form is so nasty it will only work with itself.I have never been able to work with it or remove it without using another peice of it like a magnet sort of.
I suppose that is why it seals so well.It also stays somewhat flexible for a very long time.
Ed Harris is online now   Reply With Quote
Old 01-01-2008, 06:24 AM   #9
Joe Z's Avatar
New River AZ
Like Greg above I used the 3M Marine Sealant ....Really great stuff. they have two types...The seven day cure(which i used to seal a underwater fiberglass tank) and the One Day cure (which i would probably use for various items around the fiberglass world as i believe it would be easier to remove if need be)
Joe
Joe and Linda
2013 Casita SD
Dodge Ram 4x4
Old 01-01-2008, 07:04 AM   #10
Suz
Suz's Avatar
Where the removal and reinstallion of something is not on the agenda (for butyl tape), I have found that clear RTV sealant available at an automotive store or department has worked the best for me.
Suz is offline   Reply With Quote
Removing silicone! Crystal, Huscroft Care and Feeding of Molded Fiberglass Trailers 30 07-28-2009 10:38 AM
removing old silicone from trim Roger Hunckler Problem Solving | Owners Helping Owners 6 10-24-2007 09:38 PM
Help with silicone removal John Perry Care and Feeding of Molded Fiberglass Trailers 30 10-06-2006 09:25 AM
High temperature silicone or caulking Paddy Morris Problem Solving | Owners Helping Owners 7 05-19-2006 09:13 AM
Use that WD-40 or Silicone Spray Legacy Posts Care and Feeding of Molded Fiberglass Trailers 11 11-26-2002 03:38 PM
