Slick Extension Mirrors - Fiberglass RV
Old 08-29-2011, 09:03 PM   #1
Bill Robison's Avatar
Trailer: Eggcamper
I like simplicity and functionality - so I designed and built some extension mirrors to use with my egg. Some of you have requested that I post more about them - so here you are!
Consists of two mirrors (with rear swivel bolt) from auto store - 1" x 3/16" strap steel - four expanding anchor type nuts/bolts/washer and two 3/8" bolts/nuts/washers. On the bottom of the factory mirror, strike a line parallel with the mirror angle. Carefully drill two holes for the expansion nuts and fasten a piece of strap steel as a permanent mirror bracket. Cut strap steel long enough to allow new mirror to extend just past the factory mirror. drill two holes - one for mounting and one for attaching the mirror.
I have 'brackets on my Honda ODY and TrailBlazer - use the same set of mirrors for either vehicle. It takes two - three minutes to put on or remove the new extension mirrors via one bolt each side. Make sure the bolt is nice and snug and use a lock washer, it becomes an automatic 'swing away' in case you accidently run into something with the extension mirror - if that happens just re-position and tighten the bolt. We have towed our EggCamper nearly 10,000 miles - and they stay put. I just put them back on the TrailBlazer before heading to the mountains once again - so I decided to take some pix.
Happy trails!
Bill
'Do not go where the path may lead, go instead where there is no path and leave a trail.' - - Ralph W Emerson
Bill Robison is offline   Reply With Quote
Old 08-29-2011, 09:08 PM   #2
kirkman's Avatar
Trailer: 2007 Eggcamper & Homemade Tear Drop
Cool! Nice work!
kirkman is offline   Reply With Quote
Old 08-29-2011, 09:42 PM   #3
Mike Magee's Avatar
Trailer: 93 Burro 17 ft
I bet these mirrors vibrate less than the usual ones that strap on or whatever. Very nice indeed!
Old 08-29-2011, 09:55 PM   #4
Trailer: Eggcamper
Thanks guys -
They hardly have any vibration. Note that the attachment bolt is upside down - I do it this way so the end of the bolt applies a minor amount of pressure against the bottom of the factory mirror - acts as a stabilizer and eliminates most of the vibration.
I realized that some people may not be familiar with expansion nuts - here are a couple pix. The type I used were similar - not the solid rubber - they were rubber-coated brass. Use the shortest length possible to avoid interference in the factory mirror base - typically, the the 'base' is hollow.
Bill
towing down hill on slick dirt road ronsmith100 Towing, Hitching, Axles and Running Gear 15 09-19-2009 03:30 PM
Counter Extension Don N Problem Solving | Owners Helping Owners 8 07-24-2009 09:51 PM
Extension Cord Donna D. Problem Solving | Owners Helping Owners 10 06-02-2009 03:52 AM
Extension Mirrors Monica M Towing, Hitching, Axles and Running Gear 30 02-12-2009 08:35 AM
Tongue Extension LeBoutillier Problem Solving | Owners Helping Owners 22 03-09-2006 08:25 PM
