sliding window advice needed - Fiberglass RV
Old 04-13-2009, 08:51 PM   #1
Trailer: 1972 Compact Jr
We own a 1972 compact Junior, with a sliding window in the rear door. I do not know what you call the pieces.pins, that are spring loaded that lock into place in the holes that allow you to set the bottom of the window at different heights in the window frame, window goes up and down in the door. They are a soft metal and these ones have nipples that extend from a larger block of metal with integrated thumb ridges. The ones on my window are worn off or broken off. The window has been screwed in a closed positon. It would be nice to use the window and I am wondering if these sliding, spring loaded pins can be replaced, do I have to replace the whole window, or do people have others suggestions. One could always use temporary pins supporting the bottom edge of the window but it would be nice not having to screw the window shut everytime its closed and in transit.
Kent I is offline   Reply With Quote
Old 04-13-2009, 09:11 PM   #2
Trailer: Fiber Stream
Unhappy
My Fiber Stream has the same vertical slider window in the same style entry door.
The "pot-metal" latch is broken in mine, also. If you don't squeeze the latches toward the center of the window sash every time the window is raised AND lowered, those tabs break off very easily.[b] I think every one that was ever made is now broken off. Not the upper half mind you; just the lower half! My window sash fit in the frame snugly enough that they stay in position without the tab engaging into the slot.
Old 04-14-2009, 05:42 AM   #3
Need window parts? Check here: Window and Window Parts
Old side window & door window needed sherry loving o Classified Archives 0 06-12-2008 03:15 PM
Sliding rear window Pat C Problem Solving | Owners Helping Owners 3 05-27-2008 04:35 PM
FOUND - Wanted : Rear side sliding window for Scamp DanPatWork Classified Archives 1 08-08-2007 08:34 PM
Sliding window mouldings Manitoba Paul Problem Solving | Owners Helping Owners 5 06-17-2006 07:14 AM
New van advice needed Legacy Posts Problem Solving | Owners Helping Owners 20 07-03-2003 03:55 AM
