Slow leak from grey water tank. - Fiberglass RV
Old 08-12-2019, 09:33 AM   #1
Trailer: scamp 13
I managed to run over a small tree stump with our 2015 Scamp 13 and that started a slow leak from our grey water tank right around where the large drain pipe joins with the tank. I couldn't see any cracks or anything, but it does seem like maybe the seam opened up where the pipe to the gate valve exits the tank. So I was wondering, what is the best way to fix that? I am thinking the tank and pipe are ABS plastic? (It is kind of a drip every 3 seconds or so slow leak.)
zack sc is offline   Reply With Quote
Old 08-12-2019, 09:52 AM   #2
Raspy's Avatar
Trailer: Black Series HQ19, Oliver LE2
Smith Valley, Nevada
Here's a link to the Scamp site, and maybe the tank you have.
If it is polyethylene, it is probably not glueable, but if it is ABS, it should be. Maybe call Scamp.
https://www.scamptrailers.com/parts-...nk-detail.html
Old 08-12-2019, 12:57 PM   #3
Trailer: scamp 13
It is ABS. What is the best way to repair that then? What particular adhesive and techniques seem to work well? I think the leak is probably in the seam.
Old 08-12-2019, 02:48 PM   #4
There should be a threaded fitting that goes into the tank. If that is the issue, it's a fairly simple remove and replace job. If the tank itself is damaged, and Scamp can't supply a suitable replacement, I would contact TAP Plastics for material and repair information. They have stores all over the west coast. Do it right the first time is a rule to follow here.
Old 08-12-2019, 04:19 PM   #5
Trailer: 2014 Escape 21, Lil Joe
The pipe just slides into the tank. (not threaded) Scamps seals it with silicone. You remove the old sealant and clean it up. I use alcohol and used black silicone to reseal it. There is a low spot on the tank where the pipe goes in that traps water. Jack up the trailer on the drain side to keep the water out of the joint until it cures. I also make a wood block to fit between the pipe and the floor and use a pipe strap to secure things tight. If I were to do another one I would use OSI Quad sealant, you can get it from the big box stores. It a butyl sealant that will seal even on wet surfaces. Like silicone it takes about 24 hours to cure and they are both non-workable. I have resealed three Scamp tanks with silicone and had no issues
Eddie
Eddie Longest is online now   Reply With Quote
Old 08-12-2019, 05:06 PM   #6
Raspy's Avatar
This is the right answer. The voice of experience.
Old 08-13-2019, 09:35 AM   #7
Trailer: scamp 13
Quad max
Eddie
Thanks Eddie. Do you mean this one?
OSI Sealants 1868684 9.5 oz Quad Max Window, Door and Siding Sealant, White
Old 08-13-2019, 09:39 AM   #8
Trailer: scamp 13
jacking
I could jack up the drain side, put it on jack stands, chock the opposite wheel, and then crawl under and work on it: does that sound safe? Any advice?
Old 08-13-2019, 10:14 AM   #9
That's the sealant. It comes in a lot of colors. It's usually stocked in white and clear and a few other colors. Jack stands are safe on a flat solid surface. Just make sure the joint is dry when you seal it.
Eddie
Old 08-13-2019, 10:29 AM   #10
IllAnnoy
The tank itself is likely cracked at the fitting since it is the thinner and weaker link.
I have had exactly the same experience and was able to seal it while on the road with silicone sealant.
When I got home I looked it over.
My Advice is....
For the best solution, replace the tank.
When you order it get the fitting kit with it.
You will save a bunch of aggravation.
Save the valve parts.
If you have a blackwater tank, the valve gets buildup over time which causes it to leak through and makes it difficult to cycle.
The graywater tank valve stays clean.
Use the old valve parts from the graywater to rebuild the blackwater tank valve. That's a small bonus from the replacement of the blackwater tank.
Old 08-13-2019, 04:58 PM   #11
when I was servicing RVs I had a holding tank that had dragged over a stump splitting it over its entire length. I used a tool grinder and gouged the crack out and using a plastic welder, laid three beads of weld along the crack. Entire job took about one half hour. Saw the owner several years later and he stated it had never leaked a drop.
Bing M. is offline   Reply With Quote
Old 08-16-2019, 08:58 AM   #12
Trailer: scamp 13
Plastic
Thanks Bing. That sounds great. (are you in Buellton perchance?)
I don't have a plastic welder, just a heat gun. I was thinking some JB Weld plastic bonder might work on a small crack. I have some syringes to inject it with.
Old 08-16-2019, 09:00 AM   #13
Trailer: scamp 13
Replace
My Advice is....
Thanks. Appreciate the advice!
Old 08-16-2019, 09:01 AM   #14
Trailer: scamp 13
Heat gun
Eddie
Is it okay to use a heat gun a little bit for the final drying after it is jacked up and drained?
Draining black tank into grey tank..... Joe & Cherie General Chat 63 04-19-2017 06:35 PM
Black/grey water tank leak? frank_a Plumbing | Systems and Fixtures 28 09-02-2014 08:57 PM
How do i find a VERY slow propane leak? Mouse Problem Solving | Owners Helping Owners 37 03-22-2012 06:31 PM
Leaking Grey Water Tank on Boler KevinDR Plumbing | Systems and Fixtures 7 09-01-2007 10:12 AM
